Keeping rear spoiler down
Old Oct 17, 2015 | 04:13 PM
'02996ttx50's Avatar
i suspect that while i don't understand the difference in these examples between downforce not being the opposite of reduced lift. i DO get they they are NOT directionally proportional! i'm not seeing that any of you guys understand what i'm unclear about either.
i was never attempting to quantify one ( downforce ) against or VS "reduced" lift. it was a purely semantical question, and the answer ultimately doesn't matter as i was NOT ( again ) attempting to quantify one over the other. but thanks for trying to enlighten me.
Old Oct 17, 2015 | 04:43 PM
32krazy!'s Avatar
i take it to mean that you are thinking that the downforce and the reduced lift occur at the same place. but this wouldn't always be true.
Old Oct 17, 2015 | 07:06 PM
yes, and no. my confusion stemmed from the fact i couldn't figure out how ( other than semantically! ) there could be any "difference" btw "downforce" and "reduced lift", but i now see they are not interchangeable as either terms,.. OR phenomena, and that they are NOT one and the same.
i think.. whew!
Old Oct 17, 2015 | 08:10 PM
Steve B.'s Avatar
Steve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to behold
Old Oct 24, 2015 | 11:48 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Originally Posted by pwdrhound
9kg (19.8lbs) of down force is created by the rear wing at a top speed of 190mph. At 75mph, you are looking at about 8lbs of downforce at best. It's a joke...
Ya. It has to be. I designed the Aero for my vette and it makes 1600# at 150mph. At 75, I can barely tell it's there unless I'm in a huge sweeper. If it's under a few hundred pounds, it's not worth much. Probably better for mpg over grip.
Old Oct 24, 2015 | 11:53 AM
VGLNTE1's Avatar
i agree with everything you've said, but for the purposes of a discussion of downforce vs reduced lift, aren't they essentially one and the same thing, other than semantically??
or am i missing something? as the way i see it, "downforce" by its very definition "reduces" lift (!?)
Very different. Lift is due to poor aerodynamics and packed air. Lift creates drag and bad grip. You can improve that and get zero downforce but improved performance. Down force creates extra weight over sections of the car but can also make or increase drag. It takes a massive amount of R&D to make a big downforce car that creates no little drag. Diffusers is usually the biggest help there. Flat bottom cars is the ticket there.
Old Oct 24, 2015 | 12:20 PM
I'm beginning to understand the difference! thx for taking the time.
Old Oct 24, 2015 | 12:45 PM
VGLNTE1's Avatar
The gt2/3 front bumper is a good example. The vent on top pulls from the bottom, reducing lift under the front of the car.
Old Oct 24, 2015 | 04:19 PM
that i understand ( whew ). so this, in conjunction with the downforce created by the gt2? ( or even moreso using the gt3 blade + increased height relative to the lower gt2 rear wing ) work in concert with one another?? to keep the front "lift" reduced ( front splitter/lip? ), while doing much the same thing for the rear of the car..e.g. "downforce".
so that's all they are designed to do..yes? keep the car as low to the ground as is possible overcoming the laws of physics that want it to "fly"? sort of??
is that all there is, besides the physics of one over the other e.g.; front to rear proportionality?
if so, then i'm catching on ( however slowly ). everyone else has known all this already, no doubt.
Old Oct 24, 2015 | 08:16 PM
VGLNTE1's Avatar
Just think of a car as a teeter toter. (Sp?) If you push the back down, the front comes up, vise versa. I had to add a 4" splitter to balance my 70" wing with a 12" cord(width). My wing is designed to create 1200# at 170 mph. The force exerted doesn't necessarily mean 50/50. Like 500# in back, and 500# in front. It's tuning just like a ecu. Trial and error. My wing makes way more than my splitter, but its balanced.
I took an instructor out once because I was losing grip on a dog leg that was about 140mph. Full throttle corner. I thought I was off line or doing something wrong. We discussed it and added just 1° to my wing and it then stuck like glue. It's awesome to see that stuff really work. If you look at the bottom of a 458 Ferrari, it's all flat with a diffuser and blades to accelerate the air off the back. That car makes 800# of downforce with just that, so its zero drag. Back when racing was racing, the old f1 cars and prototypes aimed their exhaust gasses over the diffuser and wings to add downforce. I think the new 918 uses that technology for high speed downforce. Fluid dynamics was always my favorite subject in school.
Old Oct 25, 2015 | 06:12 AM
appreciate the info. i'm trying to understand the vast difference btw front aero splitters and wings of various sizes on the rear and without having wind tunnel results ( which i wouldn't understand anyway ) this is the next best way. thx for explaining it.
Old Oct 25, 2015 | 09:37 AM
BLKMGK's Avatar
I'll never forget the account I read by a driver who had just switched to Porsche and was having issues with a turn losing grip. His crew chief told him - go faster! He finally did and the car stuck like glue. Neat stuff!
Old Oct 25, 2015 | 11:42 AM
thats it! stick it like glue.. we don't need no stinkin downforce ha!
Old Oct 25, 2015 | 01:33 PM
VGLNTE1's Avatar
Driving with downforce is scary at first. The invisible hand pushing you down.
Old Oct 25, 2015 | 02:00 PM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
or like the earlier 911 variants, never lift the throttle in a turn... Certain rules eh?
djcooper@rennkit.com
