Max boost pressure, e85?
k16 based turbos to flow 900+whp?
thats gt30 or above and very high boost (2+++bar) for our engines. maybe 68hta compressor wheel can generate the flow for 450hp each but paired to another (much bigger) turbine, ust to have an idea, I did with my ex setup 916hp at 2.1bar with gt32 turbos and 80mm compressor wheels and a lot of timing mix of pump/ms109 and meth, no corrections of the dyno, so yes that is maybe 1000whp corrected on a dynojet, but I assure you can run 4s 60-130 all day long at that level, show me ANY k16 car with almost stock weight to do that and will change my mind, even a K24 turbine I guess can not hit real 800whp paired with any compressor wheel, put some corrections and everything is possible, dyno queen
