Uprated IC Ducts fitted
Old Jan 18, 2016 | 01:49 PM
  #106
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
Originally Posted by GT996
Your IAT should be much lower now, compared to your outside temperature, if these ducts work. Is there any before/after data that shows the efficiency of this mod?
I mean: I have no problem with believing in things, but only in churches
Why would your IAT be lower than ambient air?
Old Jan 18, 2016 | 01:52 PM
  #107
Joe Toth's Avatar
Joe Toth is a jewel in the roughJoe Toth is a jewel in the roughJoe Toth is a jewel in the roughJoe Toth is a jewel in the rough
GT996......have you seen the graphs posted by JD. He shows a 10 degree drop in IATs.
Old Jan 18, 2016 | 04:48 PM
  #108
pwdrhound's Avatar
Impossible. At 100% efficiency, intercooler outlet temps would be the same temperature (never lower) as the temperature of the cooling ram air if it would manage to extract 100% of the excess heat. No air to air intercooler is 100% efficient. Intercooler outlet temps will always be slightly higher than ambient, delta T dependent on load, speed of cooling RAM air, and other variables. IAT's will again be slightly higher than intercooler outlet temps due to the heating of the warm engine compartment temps which heats up the Y pipe and other intake components prior the IAT sensor. The intake ducts will force more ambient RAM air through the core but that RAM air can not physically drop the temp more that the temperature of the RAM air itself. I have detailed data on various aerospace intercoolers and none can physically reduce intercooler outlet temps below that of the ambient cooling RAM air, no matter how much RAM air is pushed though the core.
The intake scoop will reduce the IAT temperature, but never below the temperature of the ambient air.
Old Jan 18, 2016 | 11:39 PM
  #109
BLKMGK's Avatar
He was speaking of delta and no one understood him, he was explaining that it should be cooler now as compared to ambient than it was previously and he was asking for data. He wasn't claiming it would be below ambient, that's obvious. What he's getting at is that there's no instrumented data here, same thing I've said. Testing on different days or claiming butt dyno differences isn't what we are looking for. Common sense says temps ought to drop and that lots more air should flow but cars and common sense don't always work that way. I've seen tiny changes make huge differences back to back to back on a dyno that left everyone scratching heads which is why data is being requested here.
Old Jan 19, 2016 | 12:35 AM
  #110
pwdrhound's Avatar
I think Johnydangerous showed a delta T of around 10ºC if I'm not mistaken. I'll have Motec data when I get to the track in March/April. I haven't touched my car since the last track day in November.
Old Jan 19, 2016 | 12:57 AM
  #111
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
Thank you. That's exactly what I wanted to say.
Old Jan 19, 2016 | 06:13 AM
  #112
BauerR's Avatar
Just ordered a set!
Old Jan 19, 2016 | 07:43 AM
  #113
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
I dont think so definitely not in Australia when its 30+ Celcius in the shade.
Old Jan 19, 2016 | 07:45 AM
  #114
timccloud's Avatar
Originally Posted by BauerR
Just ordered a set!
You will love them as much as me
Old Jan 19, 2016 | 08:32 AM
  #115
b4stiTTS's Avatar
b4stiTTS has a spectacular aura aboutb4stiTTS has a spectacular aura about
Mine also coming in the next days Carbon on Black also
Old Jan 19, 2016 | 08:56 AM
  #116
BauerR's Avatar
I was going back and forth glass Vs carbon. Been doing the same with the Strosek rear wing.
In the end I went glass.
Old Jan 19, 2016 | 12:14 PM
  #117
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Im sad to say there will be no more data from T11ABO, she crashed at hi speed on black ice
Old Jan 19, 2016 | 01:16 PM
  #118
GT996's Avatar
I don't get what you are saying. 30+ in Australia is not much different to 30+ here in Germany or anywhere else
Given the same outside temperature one should see a difference in cooling efficiency just by the plain higher flow thru the ICs, if these ducts increase the flow significantly. Nothing else is responsible for an increase in efficiency.
Yes I did see the graphs now. What shall I say. I don't have these high IATs to begin with and I do much longer pulls and I also have quicker recovery on ICs. AND my car consumes less fuel AND looks better
I am not saying that these ducts are not working, but the provided data or better assumptions are quite thin, if you get what I mean.
Old Jan 19, 2016 | 01:22 PM
  #119
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Oh no!!! So sorry to hear that, hope you're ok.
Old Jan 19, 2016 | 01:49 PM
  #120
Sore and hard to move but no bad damage to me, car insured agreed value so not all bad
