Motor mounts and Trans mounts
Old Jan 6, 2016 | 11:02 AM
SuncoastParts's Avatar
SuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond repute
Hey, if you are interested in OEM we have those available for purchase!
Best of luck!
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow us to stay connected:
Join Our Newsletter | Facebook
Old Jan 6, 2016 | 01:51 PM
'02996ttx50's Avatar
Originally Posted by daedalus
+1 for this setup.
exactly. any good semis and a new oem t-mount are going to literally transform a car that's currently still using original and by now "funky" equipment!
Old Jan 7, 2016 | 11:57 AM
I use the RSS mounts in the 997 and I prefer them over the Torque Solution ones I used in 996. I think there is less NVH from them and the benefits are the same. In 996 I used both OEM 997 trans mount and the TS Trans mount. Both worked well, this mount usually gets beat up a lot so its definitely something to keep an eye on.
#TeamAIM
Old Jan 7, 2016 | 02:11 PM
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
Do you think that the TS engine mounts eventually wear out? I've had those in my car for about 2 years now
Old Jan 10, 2016 | 02:29 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
[QUOTE=993GT;4441497]
I run T.S. 75a engine and trans mounts. Trans mount adds a ton of NVH but makes shifting perfect even loaded coming out of a corner.
+1 very happy with my TS mounts
Old Jan 10, 2016 | 07:05 AM
any/all rubber or poly will eventually ( if not "wear out?" ) then eventually lose their malleable quality. more so rubber than poly though.
i run new wevo's and have a difficult time imagining them going before i do.
Old Jan 10, 2016 | 10:54 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
T.S. is nice stuff and priced very fair
[QUOTE=timccloud;4453405]
Old Jan 11, 2016 | 01:10 AM
i think the indisputable truth of the matter is, is if that you secure to the best of your parts ability the elimination of any potential for any lateral slop at the three points that secure the motor/trans etc, then you'll have done all you can do.
i find it harder to believe though, that adding poly inserts into the NEW 997 t-mounts is going to register any discernable ( to the average joe ) diminishing of lateral moment. but hey, i've been wrong as often as right... so who REALLY knows.
window weld f1 inserts, are ok. more stuff to buy. but at least one of them is only 20 bucks lol
Old Jan 11, 2016 | 04:29 AM
timccloud's Avatar
One of the best things you can do to a 996T is get rid of the crap stock engine mounts.
Old Jan 26, 2016 | 06:11 PM
HotRodGuy's Avatar
I was going to ask if anyone had just replaced back with factory? I figured a fresh set should make a difference.
Old Jan 26, 2016 | 06:19 PM
32krazy!'s Avatar
after 10 yrs or so anything should feel better than whats in the car. doing the window weld trans mod is so cheap theres money left over for a set of t/s motor mounts which are a good quality upgrade over stock.
Old Jan 27, 2016 | 12:41 AM
timccloud's Avatar
[/QUOTE]
+1
Old Jan 27, 2016 | 06:38 AM
get a good set of semi's ( WeVo/RSS/TS/96!4 / whatever and an ssk ( 997ssk or similiar ) if you haven't already?.. and it will totally change the level of feedback the car gives you and eliminate all of the lateral slop those old parts seem to exacerbate. totally transform the car, just those couple little things.
Old Jan 27, 2016 | 08:12 AM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
Hey guys how hard is the trans mount to do on jack stands? I haven't been able to get mine out of my garage at my house to get it to a lift and want to change mine out.
Old Jan 27, 2016 | 08:26 AM
993GT's Avatar
Really no harder than on a lift, 'hardest' part is getting the undertray out, might actually easier vs a hoist.
