Motor mounts and Trans mounts
Old Dec 12, 2015 | 03:37 PM
DSCOFF's Avatar
DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !DSCOFF Is a GOD !
Given that the car is nearing 14 years in age, I figure I should start addressing the motor and trans mounts. What are the leading brands today?
90% of my drive time is on the street, sometimes quite aggressively. The other 10% is on the track. For now mostly straight line 1/2 mile, but I want to get me feet wet on a road course (but I'll start that endeavor in my E46 M3)
Noise and vibration is somewhat of a concern. I don't want to make the car unbearable, but understanding that I'm willing to put up with more than most with the car as it is today (catless, loud exhaust, triple disk clutch, blah blah blah...)
Old Dec 12, 2015 | 03:47 PM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
I installed RSS semi solid motor mounts from Sharkwerks a few months ago. Right away I noticed my exhaust sitting a little higher so there was defintely some sagging in my oem motor mounts. Sitting in the car I could feel and hear a little more rumble, nothing annoying, just enough to feel a little more connected to the car through the seat. I don't have enough experience to notice a difference in throttle response or cornering stability but I know that I like them better than my old oem.
Old Dec 12, 2015 | 03:58 PM
32krazy!'s Avatar
torque solutions motor mounts and window weld for the tranny mount. works like a charm and not much increase in nvh
Old Dec 12, 2015 | 04:08 PM
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
Might try these if you're concerned about too much NVH. Theyre relatively new, havent seen any reviews yet.
http://www.rennline.com/Tuneable-Sem...oductinfo/M18/
I put in a new 997 tranny mount with the function-first street inserts and it feels great to me.
Old Dec 12, 2015 | 04:12 PM
'02996ttx50's Avatar
any name brand "semi's" are best of both worlds for increased feedback and tautness from the car to you. that would be RSS, TS, and i use WEVO semi's myself..stay away from solids unless track dedicated. the semi's will transmit just enough added nvh so you know you've added some "performance enhancing" part.
as far as a trans mount, a new 997 t-mount will work wonders and though I've never used them or felt the need, the Function First "inserts" provide much the same solidity as the window weld steve mentioned above. but without having to do anything but install them. for most though, a new 997 mount is sufficient. the semi solids with a new t-mount, will really eliminate that lateral "slop" we all know and love.
Old Dec 12, 2015 | 08:49 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
RSS rear mounts and factory 997 trans mount do well for me.
Old Dec 13, 2015 | 01:02 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
I use Wevo's and i like it. Little more sound while idle.
If u want comfort, go for new OEM ones.
Old Dec 13, 2015 | 07:57 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
I have these. They are nice build quality. I started with the hardest bushings and left them. There is additional noise transmitted to the cabin mostly in the form of the engines natural clackity clack. There was a definite noticeable improvement in cornering and stability under straight line acceleration.
Old Dec 13, 2015 | 08:13 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
love the functionfirst units..
Old Dec 13, 2015 | 10:45 PM
white out's Avatar
white out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to behold
Function First motor mounts and window weld trans mount.
Old Dec 14, 2015 | 01:50 PM
Quadcammer's Avatar
Quadcammer is infamous around these parts
If you get the 997T transmount, I have a set of function first inserts that I'm not using.
I'll have to get you a shipping quote
Old Dec 14, 2015 | 03:50 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
I run T.S. 75a engine and trans mounts. Trans mount adds a ton of NVH but makes shifting perfect even loaded coming out of a corner, less trans noise would be nice but consistent beautiful shifts are sublime
Old Dec 15, 2015 | 05:53 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
+1 for this setup.
Old Dec 16, 2015 | 08:02 PM
viprklr's Avatar
viprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond repute
I just installed the RSS engine mounts. Would recommend.
Old Jan 6, 2016 | 10:05 AM
Twinturbofan's Avatar
Twinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud of
Can any one else who has Rennline Tuneable motor mounts chime in with a review? My thinking is use them, probably with firmest inserts then when and if I sell car (would return it to completely stock: suspension; tune; exhaust; wheels; seats etc.) I could simply put the softest inserts in instead of the worn out stock units I now have. Any thoughts?
