Can I use the 997 GT3RS Sequential Transmission
on my modified '05 Turbo S Cab?
I think that that it soesn't have the front drive output so if it can be used, could I then remove the front driveshaft, differential and halfshafts?
Thanks,
Steve
Thanks,
Steve
Originally posted by PorschePhd
Yes, but you will need to remove all of the PSM and modules as well as change the ECU program to stop looking for it. You would also need to run DME stubs in the front for the ABS.
Thanks,
Steve
