LCA build. Couple questions.
not really anyway to tell. that said massive spring rates and sticky tires will shorten life significantly...new 991GT3 has gone to a double-shear arrangement
Hrm, since alignment changes I may hold off having it done with my toe links and just do it all together come Spring. Would be less for Garth to deal with while doing other things. If you have built arms in hand are they difficult to swap? Thinking Tarett GT3 with solid thrust and monoball ends. Doubt I'll ever need to shim the ends, is there a better option? Tarett is around $1300 a set, looked at RSS, didn't find PMNCA pricing yet.
Have to find a shop local I can trust to do an alignment.
Good info here guys! Sorry if I've dragged it off topic VGLNTE1! When do you think you'll have your's done and on the road?
[url=https://flic.kr/p/oBB2Px]
[url=https://flic.kr/p/yuMdAv]
The PMNA RSR LCAs were right at $2K for the pair a year ago but might be a little more now. Tarett sells the OEM GT3 LCAs for $1385 retrofitted with the Tarett solid TA bushing and inner mono *****. The outer joint on these is the same as the normal TT arms. They also sell aftermarket arms for $1395 (they appear to be made by Elephant racing) which have rebuildable inner and outer mono *****. The problem with the aftermarket arms is two fold in my book. The mono ***** on the aftermarket arms are generally lower grade Aurora or FK rather than the German made mono ***** you will get on the PMNA arms. Additionally, since the aftermarket arms are not the exact same shape as the OEM or PMNA parts, you will have issues attaching the factory brake ducts as the brackets are make specifically for the factory parts. As such you will have to modify the brackets or use zip ties and other means to attach them all of which will be less than ideal. Just something to think about when going the aftermarket route.
It looks like the hubs have gone up in price a bit. They retail for $235 so you could probably get them around $200 or so.
Good info John!
I was just looking at the hubs and was wondering about exactly that: stress risers/material radius, and Cup hubs...knew the bearings/upright were beefier but couldn't remember if the hubs were any more substantial, and of course centre lock...
944 world has billet hubs, we should too! Hope something develops...
Cheers,
Rob
Cheers,
Rob
Hey Rob. I had several guys look at the failed hubs including a metallurgist. There is actually room to beef up the area of the hubs by several millimeters in the area that is failing. The failure point is in the section of the hub that forms the 90º angle of the neck of the hub. As you know, anytime you have a sharp angle you have a stress riser. There is actually some room to make the the 90º more gradual which would help. I am currently speaking with someone that might be able to mill out hubs out of a better material while beefing up the area in question as I would like to get a permanent solution to this problem. 997Cups have beefier hubs and I looked at that option but it would entail having the change to a center lock set up which I don't want to do.
Just finished up last night. Tried to get the alignment back to where it was, but I know I'm off and will need to hit the rack. 20* and snow flurries here so not sure when she will get a test drive. She's still down now waiting for o2s to get here Tuesday.
The install was really easy.
Looking forward to the feedback man, hopefully you get some clear weather lol. I'm interested in how the steering firms up and whatnot. I've only got 50k light duty miles on mine but being able to just swap in the new would be nice. Don't think the aftermarket interests me on this, bummer the GT3 cannot be rebuilt but chances are I wouldn't kill them quickly
That hub is terrifying John, I don't blame you for looking for a more permanent solution!
Ah okay, thought you were doing all four. Shame that stock arms are apparently back ordered. Not sure I'd need the GT3 removable ends and the other end isn't rebuildable anyway. Will be a bit before I get to this sadly and the date for the work I'm ready to do has been slipping ever backward too (sigh). I too have issues eating tires!
I just bought the race version of the powerflex poly bushings for my inner lca mounts front and rear and also my toe arm ends. It's a much cheaper option than the monoballs and is slightly less harsh. Looking forward to getting them installed along with my solid thrust arm mounts and adjustable dogbox arms.
Eric (Plug Guy)
991 Vendor Classifieds
Jan 11, 2016 09:38 AM
Eric (Plug Guy)
991 Turbo Vendor Classifieds
Jan 9, 2016 12:01 PM
Eric (Plug Guy)
Dec 28, 2015 02:04 PM
Eric (Plug Guy)
Dec 28, 2015 02:02 PM
