Turbo/Exhaust Studs
Old Jan 21, 2016 | 09:35 AM
mdurbahn's Avatar
mdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud of
Turbo/Exhaust Studs
Porsche wants $5.00 for a m8x22mm stud....I want to replace all of mine with new ones and can't pay that much ptax. These look the same, anyone try them?
http://www.grainger.com/product/GRAINGER-APPROVED-Dbl-Thread-Stud-38DL14?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/38LD30_AS01?$smthumb$
Old Jan 21, 2016 | 11:50 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
go to your local hardware store and get all 8 for 5.00
Old Jan 21, 2016 | 12:32 PM
mxracer's Avatar
mxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond repute
+1 or find an old VW shop and get them as well, same thing.
Old Jan 21, 2016 | 05:30 PM
32krazy!'s Avatar
what does pelican want for them?
Old Jan 22, 2016 | 12:19 AM
jayzbird's Avatar
jayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to behold
As long as you use the $7 washers....
Seriously, those look a little different. The non-threaded portion is a bit longer. Porsche studs are 3.3 cm total length. This is important particularly with some aftermarket cats where clearances are very tight. If the stud is too long you won't have enough room to thread the nut on.
Old Jan 22, 2016 | 08:30 AM
Dr. Jekyll's Avatar
Dr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of light
Audi and VW use the same exhaust/turbo nuts (M8 x 1.25). The VW part number is 11621711954 and the Audi Part number is 900 850 01. Both are way cheaper than the Porsche parts. I use the VW nuts and they worked perfect with both a stock exhaust and my Unobtainium exhaust.
azaytsev
Jun 15, 2016 08:16 AM
albert@velosdesignwerks
Cayenne Turbo
Jan 4, 2016 02:28 PM
