Engine Rebuild - what to change
The problem is the limited market, how many sets will they sell? I agree the pice is steep but I also recall them doing some QA and dumping a bunch of them - these are made right. If they were common or shared anything with another motor they could do volume but I don't think they are. Yes, the price stinks but unless someone can find another quality manufacturer we're stuck with it. I'd be surprised if someone wasn't already looking into it...
Oh, and I bet if you gave them good specs ARP could make them just fine. They do know how to make good hardware IMO.
ARP or anyone can build you anything you want. Its not about that but you seem to want to argue and not try to realize that 1500 for a set of studs is highway robbery and that's fine. I never said ARP are good or 10mm are good or anything. I am saying, once again, 1500 for STUDS is just ridiculously priced, period.
See, they CAN be made by ARP but at the volume they want even MORE money! If this were a less critical part you could head to Asia but for this you want rock solid QA and that really cuts down choices I'd imagine. Somehow I just knew alternatives were being sought
While I'm contemplating the studs, anyone got any more tips or bits I need to be aware of?
I've been told "crankcase core upgrades" not sure what that means
Sealing gaskets correctly?
I'll check the drillings in the forged crank are sealed correctly etc.
what most look at is the cost. 700$ for 10mm studs 1500$ for 12mm studs. factor the r&r to retorque and that difference in cost drops drastically.even 10 hrs r&r at 100$ per hr and your even in terms of cost. at 90 ft/lbs the 12mm aren't coming loose. at 60 ft/lbs the 10mm have started to show a track record of loosening up. maybe not at 800 crank but why take the risk when the solution is right there waiting to be installed?
#TeamAIM
#TeamAIM
Also the 1500$ includes the custom gaskets which are 325$ cheap they arent but they do work well
To the o/p other than new crank bearings for peace of mind the stock bottom end will take whatever hp you throw at it
also to your its only 1500$ only comment, yes it is not THAT much if it includes gaskets too. however if the machining isn't spot on you need cases - which is $2.5k. Even good builders make machining mistakes, customer always pays for that anyway.... which is why i do not want my cases machined, not to mention taking material out of them.
#TeamAIM
#TeamAIM
its not a trick. everything is done with motor out before it goes back in. also to your its only 1500$ only comment, yes it is not THAT much if it includes gaskets too. however if the machining isn't spot on you need cases - which is $2.5k. Even good builders make machining mistakes, customer always pays for that anyway.... which is why i do not want my cases machined, not to mention taking material out of them.
The only real material removed are the existing threads then new threads cut. Heads a nd housings have no threads as you know. The srm jig ensures a straight and precise cut and tap
i don't
#TeamAIM
#TeamAIM
Anyone looked at WRX studs?
m11 and 7.7" long, so will give me the 90ft/lbs.
Going by other posts the 996 are m10 x 7.765 or 7 5/8.
Close enough? I'm not in the uk so can't measure my old ones
To each his own as they say but no offense and i dont know what machine shop you use but if they are making a mistake like ruining your cases on a simple machining job as prepping for 12mm studs i suggest u get a different machine shop. They should be responsible for that if they do mess it up also . A good machine shop is insured for this type of thing. I have never heard of a set of cases being damaged from 12mm stud upgrade. Then again i think Todd BHT motor is still on those ARP studds Todd Knighton built it with. Lol
Not for nothing but BHTs car runs strong on 10mm studs, chris greens GT2, my old yellow 996tt ran strong on them too and got a lot of abuse so have a lot of other cars. Proper assembly is essential.
Nowadays there are a lot of experts out here, however I am always interested in the feedback of guys who are known to abuse their cars constantly and have cars that stay together for more than 6 months.
#TeamAIM
#TeamAIM
Well way back then ARP's were the flavor, my original motor had arps, and a bunch more.
when they failed new solutions came about.
