Value of OEM brake hardware?
Old Jan 31, 2016 | 03:42 PM
ramman5600's Avatar
ramman5600 is infamous around these parts
I am getting my calipers redone and want to get the rest of the components up to the look of what the refinished calipers should be. I don't want to use rusty spring brakets and roll pins and such with freshly powder-coated calipers. So my question is whether or not the OEM parts are really worth the price difference. For example OEM spring, pin and cotter clips are $40-$60 per axle and I can get centric parts for under $10 per axle (pictures look identical). The damper kit for the rears for another example is $92 vs $48 thru the aftermarket groups. (and before you respond, I did search for the answer about 30 minutes - but will admit my search skills are not the best) Thanks in advance for the input.
-C
Old Jan 31, 2016 | 03:45 PM
32krazy!'s Avatar
i would think the quality would be as good as porsche since they dont typically make those smaller parts but farm that work out to vendors such as centric
Old Jan 31, 2016 | 03:49 PM
ramman5600's Avatar
That was kind of what I was thinking. Thanks for the quick confirmation.
Old Jan 31, 2016 | 04:02 PM
32krazy!'s Avatar
i used zeckhausen racing for the caliper rebuild kits. about 40$ each caliper. jared will install them if you supply the kits
Old Jan 31, 2016 | 04:16 PM
ramman5600's Avatar
Thanks. He mentioned he had a source too. Are the Zeckhausen parts better than what he normally uses?
Old Jan 31, 2016 | 04:44 PM
32krazy!'s Avatar
i dont know what he uses so i cant say. zeckhausen tyically uses stoptech parts which are direct fit for brembo.
crazycarlitos
Jan 20, 2016 06:31 AM
su_maverick
Jan 19, 2016 08:36 PM
magnus911
Cayenne 955/957
Jan 10, 2016 09:38 PM
DerekShiekhi
Other Japanese Supercars
Jan 8, 2016 02:55 PM
