Rear bumper needed for 957 Cayenne Base - Sensors question
Guys,
My wife has managed to crack her rear bumper and I am having trouble sourcing a replacement.
Can anyone confirm what the part number is for a 957 Cayenne base rear bumper?
Also, it seems like a good time to retrofit parking sensors. I found this bumper on eBay which already has the sensors - are they easy to retrofit?
http://www.ebay.com/itm/Rear-Bumper-...ZWb0Sj&vxp=mtr
Also, it doesn't look as though that bumper has an aperture for the towing system that is specified on the car. Can that be cut out?
If it's not possible; I will go with a camera instead.
By the way, I've now realized that it is the lower rear bumper that needs replacing, not the upper bit. I believe the upper bit is the part that has the rear sensors so there is no opportunity to retrofit this time.
This is the part I need, although I can't seem to find a part number anywhere. If anyone can work it out, I would be much obliged.
http://www.rosepassion.com/en/cat/po...m-i0p8/P184139
