KW clubsport
KW clubsport
I have sourced a used set KW clubsport kit for 996 gt3 and as I am going for rwd with cup uprights these should be perfekt.
But i have one qustion i cant find answer on.
The colivers I have found has Shock part number 710-1006 and 710-1106
But on new shocks the part number is 712-1006 and 712-1106
Anyone who knows if there is any differnces and what it is?
If the coilovers are GT2/3 parts then yes use the GT2/3 uprights(stock 6TT rear is same)....if they are Cup coilovers then you need Cup uprights front and rear
I'd verify #'s with KW before anything..
996 Cup uprights are the same parts are the street 6GT2/3. The coil overs are different on the Cup which have shorter rear shocks along with 1370F/1484R spring rates. RS uprights are different from Cup and street GT3s..
Correct
Porsche_Shiftin04
Feb 1, 2016 06:58 PM
daedalus
Jan 29, 2016 11:47 AM
