Replace the entire hose or just the o-ring?
Old Mar 3, 2016 | 04:35 PM
Gixxed_Spyder's Avatar
Gixxed_Spyder is infamous around these parts
Question Replace the entire hose or just the o-ring?
Bought a boost leak tester from Markski (works great btw) and hooked it up and immediately found a giant leak where the lower boost hose meets the intercooler. I couldn't add more than 5 psi and that lower hose wanted to pop off and you could hear it leaking. To save time and to order the right part the first time, should I replace the entire hose or just the O-ring?
Old Mar 3, 2016 | 04:55 PM
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
Check the tabs on the hose. They tend to get pushed in and deformed which makes it easier to pop off. Simply taking a small screwdriver and pulling them out a bit would help it to stay where it should.
Old Mar 3, 2016 | 05:52 PM
jpflip's Avatar
It is really important to have the proper clip in the proper position. You can found more than 7 different size of those clips on the TT. (99610680211 99610680210 99610680212 99610680215 99610680216 99610680217 99951231700) Some of them are really just a bit bigger or smaller and if you put them in the wrong place it will pop out... If you look at the picture you will see they are similar but different part#!!!!
Hawkinz69
Bentley
34
Jun 9, 2018 10:27 AM
Johnny DB
Mar 5, 2016 10:09 AM
studio112
Feb 22, 2016 08:20 PM
Carrera316
Feb 11, 2016 09:47 PM
Trauma
Feb 4, 2016 06:21 AM
