Massive power/tq drop on Dyno, possible cause?
Old Mar 23, 2016 | 12:07 AM
  #76
nlcxmoses's Avatar
nlcxmoses is a glorious beacon of lightnlcxmoses is a glorious beacon of lightnlcxmoses is a glorious beacon of lightnlcxmoses is a glorious beacon of lightnlcxmoses is a glorious beacon of lightnlcxmoses is a glorious beacon of light
I am going to gap my plugs again this Friday as i did not check the gapping before installing.
I do hear slight misfires during deceleration, the plugs are brand new Bosch ones from pelican parts.
I will be checking for leaks as well I will also due some more logs tomorrow using a different program on my laptop as well as on Torque android app.
Old Mar 23, 2016 | 12:20 AM
  #77
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Yeah gapping plugs is big. My shop has to do mine too. I think he left them around high 20s they need to be mid 20s gap.
Old Mar 23, 2016 | 12:10 PM
  #78
nlcxmoses's Avatar
Did a pull and recorded the data on my laptop will have result up soon.
Old Mar 23, 2016 | 12:52 PM
  #79
the problem is in your toone...
#TeamAIM
Old Mar 23, 2016 | 01:05 PM
  #80
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
Tunes don't change, hardware does. Of course we've never seen the 550whp dyno chart.
Curious if OP is running the same octane fuel as the original dyno run?
Later, Steve
Old Mar 23, 2016 | 01:09 PM
  #81
nlcxmoses's Avatar
I only run 92 octane.
Old Mar 23, 2016 | 01:20 PM
  #82
nlcxmoses's Avatar
Here is the data log i did today, done in 3rd gear 2.5k to 6.5k.
File Type: csv
Old Mar 23, 2016 | 01:53 PM
  #83
996tt550hp's Avatar
You need to do lambda bank 1 and 2, boost pressure sensor, injector time, ignition angle, engine load and rpm.
Old Mar 25, 2016 | 05:18 AM
  #84
nlcxmoses's Avatar
Have new logs, was unable to post earlier said token had expired so created a new thread....
Does anyone know how to delete a thread.
Did pulls in 3rd gear was able to hit 1.2bar of boost for a second then it dropped to 1.1 bar then 1.0bar...
Old Mar 25, 2016 | 06:56 AM
  #85
32krazy!'s Avatar
pm gt3chuck the moderator. cant delete threads but he can hide it
why are you only logging to approx 5000 rpm?
Old Mar 25, 2016 | 07:19 AM
  #86
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
His last log has a wot pull to 6700 rpm. Looks like timing is getting pulled. Boost is not consistent either. Not a lot of data points with his logging device though.
Old Mar 25, 2016 | 10:46 AM
  #87
nlcxmoses's Avatar
Going to check spark plug gapping and check for boost leaks today.
Old Apr 2, 2016 | 11:09 AM
  #88
nlcxmoses's Avatar
Finally was able to check for boost leaks fixed majority of them, was unable to fix the one that sounded like it was coming from the plenum. Checking my n75 valve today to figure out if it still works Todd told me this could be causing the advanced timing and also the boost spike.
Old Apr 2, 2016 | 11:31 AM
  #89
996tt550hp's Avatar
I knew you had an issue and if its the plenum thats your main isssue. Once that is fixed you will see a huge difference.
Old Apr 2, 2016 | 11:51 AM
  #90
nlcxmoses's Avatar
I took a picture of my turbo/waste gate actuator not sure if they need to be replaced? Is it ok for the waste gate actuator to look like this?
