Oil tank drain plug seal washer size required
Old Mar 26, 2016 | 01:17 AM
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
Can some please tell me what the actual size in mm for Oil tank drain plug seal washer is. I think I may have over tightened the plug and split the washer on my last oil change about 3000 km ago, it is now leaking.
I need to get one in a hurry as I'm going on a drive day.
TIA
Jim
Old Mar 26, 2016 | 02:32 AM
JimTT's Avatar
It seems l jumped the gun and panicked but l might have under tightened it as is was quite easy to tighten a bit more with ease. I'll know in the morning.
Old Mar 26, 2016 | 07:40 AM
mxracer's Avatar
mxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond repute
For reference just in case
Oil Drain Plug (22 X 27 X 1.5 mm) washer = 900-123-118-30-M131
Oil Reservoir Drain Plug (20 X 24 X 1.5 mm) washer = 900-123-010-20-M131
Turbo Oil Reservoir (18 X 22 mm)= 900-123-140-30-M17
Old Mar 26, 2016 | 08:13 AM
32krazy!'s Avatar
reference those part # on koperformance.com you can buy all the seals for pennies vs the dealer cost
Old Mar 26, 2016 | 02:47 PM
JimTT's Avatar
So the opening is 18mm, is that correct?
Thank you guys
After tightening the plug with same washer it seems to have stopped leaking.
The local hardware store has them for next to nothing but have to go by sizing and not part numbers.
Old Mar 26, 2016 | 06:03 PM
mxracer's Avatar
Originally Posted by JimTT
Thank you guys
The case drain plug is 22mm, the tank drain plug is 20mm and the turbo drain plugs are 18mm on the ID.
Those numbers above are I.D. x O.D. x Thickness
And I'm with you on sourcing them locally, I just saved the part numbers with the dimensions when I researched them.
Old Mar 27, 2016 | 05:57 AM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
Use torque wrench.. Always!
pwdrhound
May 9, 2016 10:15 AM
Frank ( Sunnyside )
Bentley
Mar 28, 2016 01:03 AM
semicycler
Mar 21, 2016 02:50 PM
Procera
Mar 19, 2016 04:58 PM
