K24s, No Boost, big mystery
Old 04-10-2016, 11:07 PM
BLKMGK's Avatar
Gotta' be a turbo or two - fingers crossed! IF they're bad have them redone as hybrids or swap to billet k16 maybe - it'll be night and day!
  #32
Old 04-11-2016, 12:23 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Sounds like there bad or one is bad. I wonder if he checked the infamous check valve number #16?
  #33
Old 04-11-2016, 11:44 AM
Enclavet's Avatar
Enclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to behold
Figured it out. Took some advice from Sambo and took off the turbo intake pipes and put a metal screen in front of each turbo. Unplugged the MAF and I have full boost again.
Thanks all for the help. Going to troubleshoot the intake. Prob snake it like a plumber. BTW mafless feels good.
  #34
Old 04-11-2016, 12:32 PM
SamboTT@ByDesign's Avatar
Glad we are getting somewhere bud. Keep me posted and I got you.
  #35
Old 04-11-2016, 12:56 PM
996tt550hp's Avatar
Makes no sense why would you out a screen in the intake and now it boost? You got other issues it seems.
  #36
Old 04-11-2016, 01:10 PM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Is your air intake filter dirty/plugged?
  #37
Old 04-11-2016, 01:32 PM
Doesn't make sense yet. This issue is very rare where you will see .2 bar and have perfect drivability and all tests are good. The intake is simple but I wanted to help the OP not have to remove the turbo's just yet. Now we can look at the intake system and recirc/vent system.
  #38
Old 04-11-2016, 01:43 PM
Enclavet's Avatar
My guess is that one of the hoses collapse. Air filter and box is clear and have driven it without the airbox to make sure. Pretty sure it isnt the MAF too since we tried to drive it with MAF unplugged but with the intake still connected (basically mafless but going through the intake).
Anyway wont beable to troubleshoot for a few weeks. Will update when I know exactly what is wrong.
  #39
Old 04-11-2016, 05:04 PM
32krazy!'s Avatar
the screen is on the turbos to keep from ingesting a rock or debris while trying to boost.
o/p whenyou remove the intake piping be aware theres a bolt on the pass side intake manifold. the tubing has a slotted piece the sits under the bolt and if you try to pry that aluminum casting it will break the manifold. the aluminum casting is 2 piece. 1 bolt on the mani and 3 bolts at the back of the motor before it drops over the back and down. 10mm heads. and a major pia to get to. drop the motor as far as possible to reach them. theres a metal gasket between the 2 metal housings and the backside tubes are plastic. the metal drops over the back of the motor and cant be removed with the motor in the car. it hits the back body.
  #40
Old 04-11-2016, 05:50 PM
BLKMGK's Avatar
Ha! I wondered about an intake restriction but had never heard of a pipe collapsing like that! Go MAFless and run filters on the turbo, free power
So glad you found this, never thought the piping had enough flex to collapse...
  #41
Old 04-13-2016, 05:57 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
LOL
Blk, you need to change your UN to Standalonemafless.
(JK)
  #42
Old 04-13-2016, 06:17 AM
'02996ttx50's Avatar
i have had a hose collapse which resulted in exactly the same symptom(s). namely, no boost beyond limp mode. was impossible to "see" that the intake hose ( was near the plenum/tb cant recall which one exactly ) but replacing it with one we made on the spot and r&r'ing it fully cured the issue.
the key was our inability to to visually confirm the hose had "collapsed" in the middle of it ( it was more "pinched" than "collapsed" but the effect on "it" is the same.. e.g., restricted intake )
... so it was fully impeding air flow. hope that helps as a collapsed hose is a very real possibility. GL. if sam is helping you, you'll get it sorted for sure.
  #43
Old 04-13-2016, 11:37 PM
BLKMGK's Avatar
Replacing that sounds like no fun, hope it's something easily reached! Bet looking at it with a scope will be interesting - they've gotten cheap!
Stanalonemafless - I like it
pdxm5
03-28-2016 02:48 PM
changster
03-27-2016 08:01 PM
ECS Tuning - VW
03-25-2016 08:28 AM
ECS Tuning - VW
03-23-2016 09:16 AM
Quick Reply: K24s, No Boost, big mystery
