Put a deposit down!
Old May 23, 2016 | 05:33 PM
  #46
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Very nice find and price!! Always liked that color. I came from an E46 M3 myself (turbo), but was N/A previously so definitely with you on the power change. Welcome to Porsche-Landia!
Old May 23, 2016 | 07:56 PM
  #47
Slider's Avatar
I have an 01 with 120 K Miles - no issues.
Old May 24, 2016 | 12:09 PM
  #48
EstorilM's Avatar
EstorilM is infamous around these parts
Thank you! You had a turbo e46?? I would think that would be similar power wise to the 996.
Old Aug 12, 2016 | 08:15 AM
  #49
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
What issue did you get? I followed the manual which said to remove the console first as the light bulb holder can only be removed from the top of the console. Did you pull the bulb down from the housing?
I tried two types of LED. W5w from eBay with no error code and Philips LED.
eBay led worked but has a slight flickering which would be annoying for the long run. Philips would go on for a second and shut off.
I'm going to try to get a different LeD and see if it works better.
Old Aug 12, 2016 | 11:14 AM
  #50
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Originally Posted by EstorilM
Update: Just found a 2002 Seal grey 6 speed with 41k miles for 42.5k in my hometown. Lady's husband owned it (2nd owner) and passed away a few years ago. She has maintained but, but has only driven it a few times a year. Might go take a look tomorrow.
Cars that have been driven few times a year can have issues. Look over the car really well.
Old Aug 12, 2016 | 11:16 AM
  #51
996tt550hp's Avatar
Originally Posted by nick49
All 996 TT's except the Tips can potentially develop the 2nd gear pop-out. I researched this heavily during the 10 or so months I searched for the perfect, to me 996 TT.
It's generally caused by speed shifting, or shifting too quickly for the way the syncros and shift dogs are designed. If you are trans savy and know how transmissions shift and can picture mechanically what goes on inside when you clutch in, move the lever, clutch out, you can sense and feel, and time your movements according and never ever have a problem. If you like to play boy racer and bang gears indiscriminately you will certainly damage your trans and the first symptom is the dreaded pop into neutral most noticed when the car is under load decelerating in second gear.
No pop out is a great sign that the trans has not been abused.
I know some people that leave there car stock and dont race it and still have the second gear pop out.
Old Aug 13, 2016 | 08:54 PM
  #52
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
And are they the original owners?
Old Aug 13, 2016 | 08:58 PM
  #53
996tt550hp's Avatar
One owned it brand new. 2001 and 2002 have the most issues.
To test this go on a decline in second gear around 4500rpm and let off the gas but leave it in the gear.
Old Aug 14, 2016 | 06:43 AM
  #54
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
What I think ~ you never know what you getting yourself into, the car may check fine, than you gonna start - fixing everything down the list, clutch, boost leaks, coolant leaks , fuel pump, etc. I think the best way is to buy one from private party. (stay away from small dealers)
Old Aug 14, 2016 | 10:07 AM
  #55
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
The '6 Turbo trans requires relatively slow deliberate shifts up and down to not constitute abuse as far as I'm concerned. The '6 C2 and C4 can be shifted much quicker with no ill percussion down the line. The same shifting as one was used to in a same year C2 or C4 would most likely result in 2nd gear neutral pop on decel sooner or later. It's a TT thing. I've rebuilt, improved shifting, blue printed trans' for decades and you can feel when shifting any trans, when it's ready mechanically to select the next gear. It's a slow process with the TT. That's why so many people have the pop out. They try to shift it quick as possible like on a Japanese import.
Old Aug 14, 2016 | 11:54 AM
  #56
'02996ttx50's Avatar
it is true what is said re 2nd gear popout and it's tendency to be limited to MY 01-02. for later iterations of the g50 the gear stack placement was altered to create different tolerances from the first two years. my 03 is flawless, while my 02 was not and needed repair.
Old Aug 15, 2016 | 05:26 PM
  #57
HotRodGuy's Avatar
man, that's my dream color too (I repainted an old car that exact color). I settled for silver after months of searching. '01 57K 2 owner car. Paid $40K
Old Aug 17, 2016 | 11:45 AM
  #58
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
I found a private party car while I had a deposit on the dealer car. This is a 2002 with 41k miles and more options
Congrats, more 996 turbos for the bellevue area!
Old Aug 17, 2016 | 01:05 PM
  #59
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
I agree, I shift mine this way as well. When i first got her i wanted to do an ssk right away. But after driving her some, im used to the shifting already and the stock longer throw seems timed just right.
Mine is also an 03 and zero issues.
Btw, congrats to you OP
Viper1456
Apr 11, 2016 09:22 AM
santon997
Apr 11, 2016 07:32 AM
WheelB
Lamborghini
Mar 21, 2016 11:57 AM
WheelB
Mar 21, 2016 11:56 AM
WheelB
American Muscle
Mar 21, 2016 11:55 AM
