Is it possible that diverter valves ...
Old Dec 18, 2005 | 08:40 AM
DFW911T's Avatar
DFW911T is infamous around these partsDFW911T is infamous around these parts
make a difference in speed?
I changed them last week at 40k miles and then in the area that I use for a quick sprint, the car hit 135 instead of the 127 which it had hit many previous times.
The only other difference was a 10 degree (F) temperature drop, from 72 down to 62. I'm under the impression that turbo cars are not as temp sensitive as s/c'd cars or even NA cars.
They definitely smoothed acceleration on the low side of the band.
Old Dec 18, 2005 | 09:22 AM
Divexxtreme's Avatar
TC cars are extremely sensitive to temp changes. The more air a car takes in, the more sensitive it is to the density and moisture content of that air.
Old Dec 18, 2005 | 10:30 AM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
Re: Is it possible that diverter valves ...
No, it wasn't the DVs unless the stock ones were leaking under boost (and that is doubtful). It was the cold air. Turbocharged vehicles (as well as s/c ones) benefit more from colder ambient temps than n/a cars.
Old Dec 18, 2005 | 10:51 AM
Ruiner's Avatar
Re: Re: Is it possible that diverter valves ...
If he had 40k on the stock diverter valves, I would be that he was leaking boost (if he went from the stock to aftermarket).
Mine started leaking at 10k, so when I put in my Baileys, I immediately noticed a difference as I was back to holding stock boost.
Old Dec 18, 2005 | 10:54 AM
Ruiner's Avatar
100% correct. Colder air is more dense and packed with more oxygen. A boosted car (turbo or supercharged) reacts better to colded air. Not to mention that intercoolers (if your car has them) become more efficient at cooling the air charge before it enters your throttle body.
Old Dec 19, 2005 | 08:15 AM
DFW911T's Avatar
Well the combination of new Baileys and 49 degree air helped me to glimpse .9 last night on an otherwise stock engine.
One of the few benefits of winter.
Old Dec 19, 2005 | 10:11 AM
Ruiner's Avatar
Oddly enough, I find that I boost LOWER in the winter as the charge is already so cold and compressed, I do not need to boost as high in order to obtain the proper air/fuel ratio.
Old Dec 19, 2005 | 10:56 AM
DFW911T's Avatar
I wonder if the added boost in my case is due to the gas mix in DFW during ther winter?
We have a special summer blend using MBTE that's supposed to benefit air pollution (less) - it actually works against air quality and the law has been changed to eliminate it sometime in the next 2 or 3 years. (Private imdustry tries to correct mistakes immediately, the government ... depends on how powerful the special interests are.)
Old Dec 19, 2005 | 11:09 AM
Ruiner's Avatar
You wouldn't get higher boost unless the octane rating of the gas increased for the most part. Higher octane advances the timing and also the boost a small bit until knock is sensed (I am guessing that the Porsche ECU has a learning curve like this...)
Old Dec 19, 2005 | 06:45 PM
Ruiner's Avatar
DFW911T - I took my car out and briefly hit 0.8 bar in 6th gear today (from perhaps 2900-3100pm or so). It was about 46' outside when I did this.
Pbread
Jul 23, 2016 08:00 PM
bongnation
Sep 25, 2015 02:58 PM
PupC
New Member Introductions
Sep 21, 2015 03:30 PM
ECS Tuning - BMW
Sep 16, 2015 03:11 PM
Bmanny
Sep 16, 2015 08:29 AM
