P0203 Porsche Fault Code 154 - Injector circ. cyl. 3
Old Apr 24, 2016 | 03:14 PM
olwe's Avatar
olwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of light
Three mornings in a row my car has run on five cylinders throwing Fault code "P0203 Porsche Fault Code 154 - Injector circuit cylinder 3" (Durametric lingo), with corresponding P0300 and P0303.
After the engine has warmed up the car starts running fine (including 230 miles on Sebring yesterday). I am in FL so "cold start" is a relative term.
I am running 70 lb injectors and Evolution Motorsports GT 660 tune with no recent issues. I did kill the battery with the lights recently and recharged it with a charger. The voltage meter acts normally.
Can someone please provide guidance for what the problem is?
Old Apr 24, 2016 | 07:11 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Does this code happen when you are at WOT? sounds like a cam bracket, variocam or coil packs.
Its not a bad injector.
Old Apr 24, 2016 | 07:19 PM
Macster's Avatar
First I'd advise you to replace the battery. Lead/acid batteries do not like being fully discharged. While you are able to resurrect the battery with a charge it is not as good as it was before. Wihle I don't think the battery is the cause of the symptoms a weak battery can cause other problems.
Next I'd check that for injector indiciated by the error code that its connector is secure. It may help to disconnect the connector then make the connection again and be sure the connector is secure.
If the error appears again it points to a bad injector.
Old Apr 24, 2016 | 07:40 PM
olwe's Avatar
First answering 996tt550hp: It happens at all rpm's and throttle postions until it goes away. Then it runs fine.
Macster: The battery is relatively new; I just managed to leave the ignition on overnight. Let me check my connectors on fuel injector on cylinder #3.
Old Apr 24, 2016 | 07:43 PM
996tt550hp's Avatar
When does it go away? You might have a bad coil..... What coils do you have on there? Have you updated to the 997 coils? When was the last time you changed them?
Old Apr 24, 2016 | 09:32 PM
olwe's Avatar
I am not sure what coils are on there, likely meaning they are stock. As fa as I can recall they have been replaced once.
I will check on both coils and connections. Is it common to change to 997 coils?
Old Apr 24, 2016 | 10:10 PM
996tt550hp's Avatar
If you have 997 coils no they should last a long time.
YBE
Cayenne 955/957
16
Dec 17, 2020 09:31 PM
magoochi
May 11, 2018 02:43 AM
BUILT4BOOST
Apr 24, 2016 07:27 PM
SPEC V
NY Tri State
Mar 29, 2016 05:40 PM
