996tt suspension question
Old May 21, 2016 | 05:40 AM
168Sierra's Avatar
168Sierra is infamous around these parts
I recently purchased a 2001 twin turbo and want to upgrade the suspension.
I purchased a set of Ohlins R&T coil overs , Eibach adjustable sway bars, Tarret drop links, solid LCA bushings and adjustable toe links for the rear.
My goal is to improve street performance on twisty roads and very occasional DE use.
I purchased all the nuts, washers, spacers etc to assemble the coil overs prior to installation form Prosche.
My questions are:
What is the signifance of the different hieght spacers listed in the factory parts manual that are located on top of the springs (IIFC they are 3 and 6.5mm for the front and .5 and 2 mm for the rear)?
Is there any way to to tell which are installed on the vehicle other than by visual inspection?
Old May 27, 2016 | 12:01 PM
sprinterman's Avatar
sprinterman is infamous around these parts
Sounds like the spacers are used to setup the spring compression to adjust the ride height. You can probably use either spacer - The larger spacer should give you slightly higher ride height due to compressing the spring more.
Old May 28, 2016 | 06:55 AM
168Sierra's Avatar
Thanks for this information
Thered300zx
Apr 5, 2016 06:42 AM
semicycler
Apr 2, 2016 09:32 AM
white out
Mar 30, 2016 10:01 AM
82chilam
Mar 27, 2016 12:22 AM
flewis763
Mar 24, 2016 07:40 PM
