315/30-18 availability
Old Dec 21, 2016 | 05:23 AM
'02996ttx50's Avatar
to hear it told, a wider rear offers a greater contact patch. all else being equal.
this is probably why gt2's run 8.5 X 12 rear. some folks run 9's in front as i have.
yes, you can tell the difference, though admittedly it might be difficult to quickly notice the difference if you're running down a hi-way on a 295/30 VS a 315/30. but given enough varied driving conditions and seat time, you'd know.
to your point re:aesthetics. a 315/30 with 15mm spacers fills in the wheel wells perfectly. form following function.
Old Dec 22, 2016 | 01:03 AM
bansasn's Avatar
bansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to all
I have 17mm spacers with my stock wheels. I am also thinking about mounting 315. Are the 17mm too much compare to 15mm if I mount 315?
Old Dec 22, 2016 | 06:47 AM
^ i don't know with any certainty but its only an add'l 2mm's more? but i'd bet there is a reason that the 15mm spacer on the rear is the most commonly accepted size to widen the stance with spacers on this platform? but I'm no expert, though i ran 7X15 spacers lowered ( approx 40mm ) on stock twists X 235/40 - 315/30 and the ride and stance was near perfect. wheels filled the fenders perfectly. again, a very common setup, presumably for a reason.
Old Dec 22, 2016 | 11:30 AM
bansasn's Avatar
I used the spacers size recommend by Porsche. 5mm front and 17mm back. So far the rear looks perfect. Just curious if anyone with this setup have any issues when mounting a 315.
Old Dec 24, 2016 | 08:35 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
I ran the 7/15 also and it looked money. Also tracked with that setup. Different wheel offsets obviously change that, but for twists it's perfect
Old Dec 27, 2016 | 11:59 AM
911mhawk's Avatar
911mhawk is infamous around these parts
Originally Posted by Rodstertts
May I ask? What are some of the reasons you would want to go to the 315 wheel.
Here are some tire comparisons siting the quantifiable difference. What can you say? Just wondering if those who've driven on both can actually tell the difference. Not sure if the revolution per mile difference of -1.9% makes a difference on the odometer or not? Given these stats, what would seem to be more reason to go 315 would be more for subjective aesthetic appeal filling in the gaps. No?
The 315 is a better match for the 245/40 in the front too(w/awd) and you end up with more rubber in the road, as well as the improved aesthetic you mention.
spooltime
Apr 22, 2016 09:58 PM
DerekShiekhi
McLaren
Mar 25, 2016 06:31 PM
Polar993
Mar 24, 2016 01:04 PM
ECS Tuning - BMW
Mar 22, 2016 06:52 AM
