Drive train noise developing
Old May 28, 2016 | 12:57 PM
olwe's Avatar
olwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of light
2001 996 Turbo with TipTronic. 88k miles - many on track, over 600 hp since new. Engine and transmission have been rebuilt.
The car has gradually started making a rumbling noise, similar to driving with spike tires on dry road. I thought it was just the Pirelli rears making noise but it has gotten gradually worse. Turning the tires over made no difference. I have not been able to lift all four wheels to try to diagnose but now think it is either the differential or a rear wheel bearing. Do you knowledgeable and experienced guys have suggestions of what may be the issue based on the above description?
Old May 28, 2016 | 01:46 PM
BLKMGK's Avatar
CV joints on the axles maybe?
Old May 28, 2016 | 02:04 PM
olwe's Avatar
I should have included: Entire rear axles were replaced a couples of thousand miles ago.
Old May 28, 2016 | 06:20 PM
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
Based on described symptoms, it certainly could be a wheel bearing. Get her on a lift and look for play.
Old May 28, 2016 | 09:35 PM
olwe's Avatar
Thanks for the feedback.
I am away from home. Does anyone of you recommend a mechanic around Glenwood Springs, CO?
Old May 29, 2016 | 09:21 AM
'02996ttx50's Avatar
if you suspect a worn wheel bearing, a simple yet effective way to further diagnose this is to "slalom" left/right a few times. if the noise abates on turning then the wheel bearing on the opposite side of the turn indicates it is the source of the rumbling. e.g.. turn left - noise stops - check right rear, etc.
Wealth Manager
Aug 8, 2016 05:13 PM
acs370
Mar 30, 2016 08:26 AM
Polar993
Mar 24, 2016 01:04 PM
ECS Tuning - BMW
Mar 22, 2016 06:52 AM
