Center Exhaust/Diffuser Project
Old Aug 8, 2016 | 04:05 PM
  #46
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
what did you use to make the fins?
Old Aug 8, 2016 | 04:18 PM
  #47
heavychevy's Avatar
Thin sheets of aluminum.
Old Aug 8, 2016 | 05:32 PM
  #48
Thanks man! Thinking about doing something like this for my IS
Old Oct 18, 2016 | 06:40 AM
  #49
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
When you were AWD what tire setup have you been using to keep fronts at least the same size as rears?
As I search for slick can find pirelli 265-645 and 325-650 the same diameter size, michelin 27/65(if they wil fit) and 30/65, some hankook 260-660 and 300-660 etc
for R compound tires if chasing a wider tire in front is hard to find exactly matching tires
If there was no restriction/penalty would you keep your car AWD ?
Old Oct 18, 2016 | 11:33 AM
  #50
VAGscum's Avatar
Originally Posted by heavychevy
Decided to figure something out after years of talking about it. My mechanic (one of them) is a top notch fab guy. Built the center exhaust and we fashioned the diffuser together. Testing at end of July at Barber motorsports park. The mounting solution for the rear was so simple, just needed the right stuff.
Still in development, but coming along nicely.
Wow! Great work!! I always thought the center exit slanted tip RSR style would be pretty neat with a diffusor. What kind of sound does that exhaust have? Anywhere near the cup car sound?
Old Oct 18, 2016 | 01:39 PM
  #51
heavychevy's Avatar
They dont have to exactly match. Keep them within an inch and you will be fine.
I would have removed awd anyways as its one of the easiest and cheapest ways to lose 75 lbs. Its so hard to make these cars really light. Performance is a wash unless its raining.
Sounds FANTASTIC. Much better than the usual straight pipes. Like a cup car with mufflers.
997 Turbo Vendor Classifieds
Apr 12, 2016 01:39 PM
proTUNING Freaks
Apr 6, 2016 06:45 PM
Whendricks
Cayenne 955/957
Apr 5, 2016 09:18 AM
