Limp mode with no codes
Old Jul 5, 2016 | 10:17 AM
magoochi's Avatar
magoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant futuremagoochi has a brilliant future
Originally Posted by 996tt550hp
When going fron the turbos there should be losing boost. I just had mine done today and it holds steady.
Well, I've been told that it is "normal" for the pressure to go down slowly(1 psi every 30 seconds or so)when doing the test from the turbos. If you think about it, it would be normal for some air to get by an open valve and out the exhaust.
Old Sep 8, 2016 | 07:07 PM
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
What about when you get limp mode after driving over a bumpy (rough) road?? Constantly happening on the same road spot. Any though were or what to look for?
Old Sep 8, 2016 | 09:40 PM
Slider's Avatar
This sounds like a loose connector - MAF maybe?
Old Sep 8, 2016 | 09:57 PM
Lucid Moment's Avatar
Lucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to all
Any updates on this? Spoke with Sam a few weeks ago, he said you guys were going to try a new base map.
Old Sep 11, 2016 | 03:49 PM
Macster's Avatar
All I can suggest is you get an OBD2 code reader/data viewer and observe various engine/DME telemetry in real time while you drive over the rough/bumpy road. Ideally you would want an OBD2 code reader/data viewr that offered the ability to log the telemetry. Durametric I think does this rather well based on logs I've seen posted by those who have used a Durametric.
I know some off the shelf OBD2 tools do this. I have one from way back when that does this but only logs about a minute's worth of data. That is probably not a big enogh window unless can trigger the behavior on a specific spot on the road.
I'm less enthusiastic about trying to wiggle the connections of various sensors. One has to be very near a running engine and there is the risk of injury if one touches something hot, or gets a shock, or gets a piece of clothing or body caught in the accessory drive.
Old Sep 11, 2016 | 06:58 PM
Slider's Avatar
I would suggest checking the connections with the engine off to start...
Old Sep 12, 2016 | 11:22 AM
HotRodGuy's Avatar
Just since you're mafless, and since everyone else has suggested it, it's probably your maf
i kid
Old Sep 14, 2016 | 03:40 PM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
I find it hard to believe you hit limp mode without a code being thrown. You need a Durametric readout.
Old Sep 15, 2016 | 07:30 AM
gclasse's Avatar
got a code today!! MAF low input value!!
Old Sep 15, 2016 | 07:35 PM
ASLAN's Avatar
^Good place to start.
Old Sep 15, 2016 | 08:05 PM
gclasse's Avatar
Maf is gone!!
Yeap!! Maf died today!! No actual reading and got the check engine..
overzealous1
Cayenne 955/957
Oct 11, 2017 12:39 PM
AdPock
Lamborghini
Apr 20, 2016 04:46 PM
Moonwalker81
Apr 8, 2016 12:51 PM
unisist
Cayenne
Apr 7, 2016 03:00 PM
ECS Tuning - VW
Apr 7, 2016 10:59 AM
