Battery disconnected and emergency hood release not working
Old Aug 29, 2016 | 12:02 AM
Slider's Avatar
You can also just hook up another battery (or 12V power source) to the cigarette lighter and use the electric hood release (front or back).
Old Aug 29, 2016 | 01:00 AM
BLKMGK's Avatar
Whoa! You're doing way too much work here, no need to disassemble anything!
Had my negative terminal pop off as well. Got a lighter plug with lugs on it, hooked it up to another car with jumper cables, popped the hatch - NO PROBLEM! Obviously do not start the car this way as the load will blow a fuse but this will open the hatches easily and in fact I've done it about ten times but only once with a ground cable completely disconnected. I keep one of these lighter plugs in my glovebox and another in my toolbox I've used them so many times...
P.S. In case it's not obvious, our lighter plugs are powered all the time. We can power the electrics or trickle charge the battery via the plug as a result.
Old Aug 29, 2016 | 08:24 AM
cadamson's Avatar
cadamson is infamous around these parts
On my way to Autozone now to pick up one of those chargers, if this works I'll be pumped!
Old Aug 29, 2016 | 11:37 AM
HotRodGuy's Avatar
Originally Posted by 32krazy!
i had a terminal pop off and was able to jump from the rear and pop the front lid from the cabin
same here
Old Aug 29, 2016 | 11:42 AM
HotRodGuy's Avatar
FYI, my '01's plug is not powered all the time, shuts off after about 60 minutes.
Old Aug 29, 2016 | 11:51 AM
cadamson's Avatar
Got it to work! I bought an emergency charger with a cigarette lighter attachment. I hooked it all up and nothing happened, but the charger was also acting as if it wasn't connected to anything. So, I checked the fuses, and sure enough, the fuse for the cigarette lighter was blown. I had no clue because I have literally never used it in this car. Replaced that, and it worked immediately. Thanks for the help!
Old Aug 29, 2016 | 05:29 PM
Slider's Avatar
Check your work... I have an 01 - power to the cigarette lighter is always on...
Old Aug 29, 2016 | 06:30 PM
32krazy!'s Avatar
now that you have the lids open find the cables and reroute them so you can get to them when needed
Old Aug 29, 2016 | 06:53 PM
cadamson's Avatar
Definitely, that's this Saturday's project.
Old Aug 29, 2016 | 10:48 PM
BLKMGK's Avatar
Happy to help, it's happened to me too many times! When I leave the car for long stretches in the garage I sometimes pop the frunk just in case - even with the tender lol
Old Aug 31, 2016 | 07:46 PM
0396's Avatar
0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute
Originally Posted by cadamson
Will I be able to jump it if the negative terminal of the battery upfront is disconnected? I can't get the decklid open, but maybe I'll search for a way to manually do that so that I can access the manual line under the tail light (might be easier than accessing the cable under the bumper)
Interesting concern, I simply don't know how the switch for the front trunk is going to operate- especially if the negative cable is disconnected...all the electronics are triggered by the "battery "- unless Porsche has a secret like to the rear engine "hot" terminal
Old Aug 31, 2016 | 07:58 PM
Slider's Avatar
If the front negative terminal is disconnected, as far as your car is concerned - there is no battery. If you jump from the rear and connect the negative terminal, you are providing the ground that the car requires and everything will proceed as "Normal". There are many ground connections within the car's wiring that well ensure the ground is good.
Old Aug 31, 2016 | 08:01 PM
0396's Avatar
Wow, thanks for the education. Since that's never happened to me, I guess I never knew. Learn something every day...forgot about all those ground points.
Old Aug 31, 2016 | 10:49 PM
BLKMGK's Avatar
The car will run just fine with the ground at the battery disconnected, mine came loose driving and I found out in a friend's driveway. Plugged into the lighter, popped the hood, fixed it! I thought something serious had occurred when turning the key produced ZERO electrical response but a friend told me it was likely the ground terminal and was right - whew!
C4SxM5
Cayenne 958
15
May 12, 2016 07:42 AM
Jeff_335i
Mar 30, 2016 08:29 PM
dmilzoff
Dec 17, 2003 08:49 AM
KPV
Nov 20, 2003 04:28 PM
CAPTLST
Aug 26, 2003 11:23 PM
