Adapters for gt3 offset 380mm rotors
Ok guys, well I got a great deal on a set of gt3 offset 380mm front rotor (Well at the 350mm rear but all the same as tt) to go along with my cup car calipers.
Issue here is after many phone calls, no one makes an adapter to mounts the calipers on a tt using the gt3/cup hat offset. The advantage of the gt3 offset is there are more rotor options.
From this I will be machining the adapters to make this work at a local shop. Offset is 2mm different than tt which means the caliper moves 2mm furthers toward the wheel (.08 of an inch) Wondering if anyone else is interested in them? Not looking to make any money just offering if needed.
Moderator of this post is an issue just let me know. Thanks
