Good Aero wing on 996TT
I've been talking to Good Aero about building a swan neck mounted wing for my 996 turbo. The biggest concern is finding a decklid that will be able to withstand the downforce that the wing will produce. Has anybody put one of these on their cars and if so which decklid did you use? Did you have to reinforce anything?
Thanks for the help! -Cyneric |
Most don't attach to the decklid but go through it to the car's chassis
Good to know! How do they open the decklid then? Remove the wing uprights?
Thanks for the input. I guess the answer is both. I still drive the car on the street but would rather have a fast track car than a great street car. My goal is mainly performance driven but aesthetics are a factor.
A wing should never be mounted to a Trunk always to the frame. if you want it to work efficiently that is
https://cimg4.ibsrv.net/gimg/www.6sp...4a5d561306.jpg
LolA getty type decklid will work. Frame mounting isnt needed on Porsche's, even cup cars. There is ample support under the decklid. The goal is to get air flowing underneath the wing anyways, not pressing down on it. Front engine cars mount to chassy because the trunk lids are flimsy. |
Originally Posted by heavychevy
(Post 4581621)
LolA getty type decklid will work. Frame mounting isnt needed on Porsche's, even cup cars. There is ample support under the decklid. The goal is to get air flowing underneath the wing anyways, not pressing down on it. Front engine cars mount to chassy because the trunk lids are flimsy. Is that your car? I've been talking to Mark at Getty and there were some concerns about the support of the wing but that picture looks like a getty decklid and cup wing. I guess I could always fabricate some reinforcement if need be. Regards, Cyneric |
Yes. What were the concerns?
Mainly the amount of downforce and stress on the decklid itself. Your car looks awesome! That rear diffuser is sweet! Custom made?
(Post 4581670)
Getty builds a lot of decklids for a lot of race cars. I tested mine up to 170 mph regularly for almost a decade now with no issues. The question would be if you top mounted it or bottom mounted it. I see a lot of good aero wings are top mounted. With it being so far back, that could present a lever effect and stress the lid that way but these are well built units. I'm looking to put a 70 inch wing on mine at some point. Right now at 63. You will only run as much DF as you can balance with the front DF. Honestly I don't think that will be the issue. The diffuser is more like hommade by me and my mechanic out of some alumalite. The whole bottom is covered with it. |
I plan on going with a top mounted wing that is about 70". Do you know of any differences in strength between FRP and CF in the Getty decklids with more of a lever type stress on the mount?
Do you have any issues with overheating when you're running with all of that alumalite under the motor? |
(Post 4581749)
Do you have any issues with overheating when you're running with all of that alumalite under the motor? Yeah, its definitely hotter back there with the alumalite. Never while driving though always when I pull off from a session and partially because I have no fan. |
I put 1/8 inch steel inside the deck lid to mount my 3/8 aluminum uprights. I don't know how other manufacturers do it, but it is extremely strong and I wouldn't hesitate to stand on the wing.
https://cimg0.ibsrv.net/gimg/www.6sp...f1eb3ec49f.jpg The whole thread about it is here... DIY - GT3-RS-Wing |
Awesome car! Thanks for the info and link to the thread. Super helpful.
