996tt tire size concerns are they real?
Old Jan 5, 2017 | 10:16 AM
  #31
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Originally Posted by brnrdtns
Freddy what do you think about me trying to fit a 235/40/19? 26.4 inch tall. Just two tenths less clearance to the liner than your setup is, but a bit thinner. Is this possible? It would be perfect with the 305's in AWD configuration.
it's probably possible but you won't gain much turn in. A 255/35/19 would be better and could run a 295 rear. Both are at 26.0
Old Jan 5, 2017 | 10:18 AM
  #32
flewis763's Avatar
Originally Posted by Serial
Someone really awesome should put together a simple chart that shows us stock tire sizes for 18" and 19" AWD and RWD and what plus sizes can work for 18" 19" and 20" wheels, with what necessary Wheel Widths, and then tire sponsors and dealers can tell us what they have in stock in most cases what they don't have in stock anymore.
Could call it factory specs and proven aftermarket specs.
this wouldn't be overly hard to do but fitment largely depends on suspension and fender mods done to a car. Simply rolling fenders allows you to run much more aggressive offsets and larger tires.
Old Jan 5, 2017 | 10:34 AM
  #33
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
Originally Posted by pwdrhound
Hey Chris,
I'm gonna have your Guard LSD ready to ship by the end of next week. Once you get that installed there's no reason to keep AWD. Sell it before you burn it out. I got $2k for mine 4 years ago. Keep in mind for 275/335s you'll need 9.5/12.5s at least. 9/12s won't cut it. I have some bad *** E88s that would round out the package for you. A good divorce lawyer might be in order at that point...
SWEET!!!
Shoot me a text when you're ready
Yeah, I've got a whole "while Im in there" list that will be happening while things are out for the LSD to go in... I'm gonna need that lawyer's number for sure if I buy wheels
Old Jan 5, 2017 | 10:46 AM
  #34
flewis763's Avatar
Originally Posted by SeattleTurbo
SWEET!!!
just a side note on 275/335 setup. I talked to forgestar 2 weeks ago because I wanted to get a set of 18s but needed to fit the 380mm brakes. Forgestar said they have a version 2 of the f14 that will be available in starting in late February/early March that they redesigned to clear 380mm brakes easily. Also 13 inch rears are now available.
that's what I'm going to pickup a 10/13 f14s. Most affordable option for me.
Old Jan 5, 2017 | 02:56 PM
  #35
pwdrhound's Avatar
Just make sure you don't buy RTF (Race Tech Forged) wheels. Many documented wheel failures across various forums. These guys are scam artists that apparently bought cast Chinese/Taiwanese blanks which they machined on the surface passing them off as forged. Caveat emptor! RTF has been banned here, rennlist, and other forums. I'm only aware of one set that ended up on a white 996TT whose owner may be on this forum.
Old Jan 5, 2017 | 03:27 PM
  #36
Ive been following the RTF stuff as well... Just another reason to stick to reputable wheel makers such as BBS, Finspeed, CCW, etc. I don't want to be a guinea pig with something as critical as a wheel.
Old Jan 5, 2017 | 04:48 PM
  #37
'02996ttx50's Avatar
i also wouldn't again use f14's, and certainly not a first batch of a new iteration of them. caveat emptor, is about right.
Old Jan 5, 2017 | 10:15 PM
  #38
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
I like this setup but I dont think a 295 will fit on a 12 inch rim.
Old Jan 5, 2017 | 10:19 PM
  #39
brnrdtns's Avatar
I put 8k miles on a set with no problems. The hub spacers work fine. Your wheels didn't work because you put the wrong shaped bolts in them not because they are terrible wheels.
Old Jan 6, 2017 | 03:16 AM
  #40
perhaps, but i didn't find them to be very sturdy either, but at least i blamed the rock i "met"
but thanks for telling me why i didn't "like" them lol. also, as you "know" they are fairly generally known to be sub par in manufacture relative to properly forged wheels. to say nothing of them being not "hub centric" ( in 18's at least ) back when. perhaps that is also changed? but i "get" why they are so popular. cheap, functional and available in custom sizes. if not optimal, they still work and at 375 a pop? you can afford to track rash them with impunity.
but either way, any complaints i *may* have had with them is very 2015 and i've happily moved on to some cheap oz wheels, thanks very much (..and yes, i realize they too are cast )
so NBD.. have at 'em!
Last edited by '02996ttx50; Jan 6, 2017 at 03:28 AM. Reason: "casting" further aspersion
Old Jan 21, 2017 | 11:09 AM
  #41
johnspeed's Avatar
I have run 295/35 /18 rears with 235 fronts, .5 inch diameter difference which I measured on stock rims ,,, for 20, 000+ miles and hundreds of dyno tests and many 180 mph sprints, No problems.
I did switch to 245 fronts though, almost identical diameters, for a better look .
I have posted threads in the past years on this.
Old Jan 21, 2017 | 12:17 PM
  #42
brnrdtns's Avatar
My concern with smaller fronts is that there is less power being sent to the fronts and I also have 12 inch rear wheels so 295's wont fit and 305's are questionable. No matter though. I am getting things set up so we can get 315/25/19 + 235/35/19 Continental Sportcontact 6 tires from Germany and this problem will be solved.
Old Jan 21, 2017 | 01:01 PM
  #43
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
^^^ I have 12 rears and 9 fronts. I used to run 315/25 but now run 305/30. No issues the 305s rubbed liners a bit but no biggie. If you can stick with 315/25 that's the correct combo for 19s.
Old Jan 21, 2017 | 02:59 PM
  #44
John@SpeedTech's Avatar
Originally Posted by MD996TT
All good info but we are a bit off topic. Have any of you that run a larger diameter rear tire than front experienced any ill effects?
Yes, I once changed only two rear tires to new and kept the worn fronts on. The difference became enough to send the car into psm on high speed highway off ramps a few times. Scary. I put on all new and it never happened again. And these were matched sets. Personally, I would never stretch the ratio for fear of this....
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Jan 22, 2017 | 09:27 PM
  #45
MotoJB's Avatar
MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !
Hey Pwdrhound...I am the guy with the white 996tt running these RTF rims. Have had no issues.
Please cite your source and proof around your claim of them passing off cast wheels as forged. Thanks.
