Annoying hesitation 996tt
Old Jan 30, 2017 | 06:44 PM
uwrasta's Avatar
uwrasta has much to be proud ofuwrasta has much to be proud ofuwrasta has much to be proud ofuwrasta has much to be proud ofuwrasta has much to be proud ofuwrasta has much to be proud ofuwrasta has much to be proud ofuwrasta has much to be proud ofuwrasta has much to be proud of
To be honest this might be totally unrelated cause mine hesitates only when I accelerate from a stop or when I have my foot off the throttle and back on to accelerate. And only in 1st gear or when I start out in second. At no other time is there hesitation through the rpm range. Less than 1000 rpm I'd say.
Old Jan 30, 2017 | 06:47 PM
SamboTT@ByDesign's Avatar
I think you are on the right track. These cars are not the most responsive to begin with and "secondary air" has been a hunting issue since they came out!
Old Jan 30, 2017 | 06:51 PM
'02996ttx50's Avatar
the car doesn't like to do anything moving under 1k rpm .. and it does like ipd plenums while being decatted. parts need to be matched, and some match up better than others.
i think your issue is wholly different from the op's. just don't expect much from starting out in 2nd or under 1k rpm... it will never be happy.
Old Jan 30, 2017 | 08:10 PM
acs370's Avatar
acs370 is infamous around these parts
Originally Posted by uschoice
Are you running the stock air box?
I have mafless, straight pipe and Evoms cone filter. But the issue was there before any mods.
Old Jan 30, 2017 | 08:17 PM
acs370's Avatar
Originally Posted by MARKSKI@911tuning
your the 3rd person describing the same issue... put the stock tune back in and see if it goes away... don't get on boost... sometimes mafless and big injectors do not go well together. Do you have a 74 mm IPD plenum?
Good idea, I'll try the stock tune.
Running Stock plenum. What's the TB reset got to do with this issue since the hesitation goes away momentarily after, but comes back almost instantly?
Old Jan 30, 2017 | 08:20 PM
acs370's Avatar
Originally Posted by SamboTT@ByDesign
You can try your stage 2 OTS map and plug the MAF back in. The only issue with that is the MAF will help mask and clean up the issue you likely have. Still We have MAFless cars from 500 to huge hp no issues. I think something is off and changing that venturi valve will be a good start u. I am here as usual for you.
Then if anyone has my set up try to log it happening and feel free to send over. There are too many cars that run fine to blame the Cobb MAFless but we can work together to figure it out
I will try to log it and send it to you.
Old Jan 30, 2017 | 10:02 PM
acs370's Avatar
I noticed the hesitation occurs always on the same throttle application. With slow steady pedal application, throttle angle jumps rapidly from ca.5% to over 8% and the stumbling occurs. Like the throttle plate was sticky? I'm still suspecting faulty TPS without triggering codes. I sent Sam some loggings, hopefully he finds something.
Old Jan 30, 2017 | 10:18 PM
uwrasta's Avatar
Thanks man. Let me know what transpires. My hesitation is liveable but it's just different than stock and maybe the nature of the car with such high flowing outlet. Maybe I just need new turbos and intercoolers now so the front side matches the back
Old Jan 31, 2017 | 06:22 AM
bsh's Avatar
bsh
bsh is a name known to allbsh is a name known to allbsh is a name known to allbsh is a name known to allbsh is a name known to allbsh is a name known to all
Log ign angle and see if it is stable when hesitation occurs.
Old Jan 31, 2017 | 09:35 AM
She's a slight bit lean at that tip in point where you're feeling it. Going to make an adjustment but check with my team to see if we can see something causing it. With the throttle being stuck I would almost expect to see the opposite. It could just simply be the set up so I'll send you something to try today mate! How does she feel otherwise? Is the last adjustment we made running good?
Old Jan 31, 2017 | 11:52 AM
bansasn's Avatar
bansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to allbansasn is a name known to all
I get a weird hesitation to. At idle about 800-900 rpm it sometime has a hick up idle drop a bit and it picks back up immediately. You still could see the needle struggling to stay up to normal idle. Eventually it became normal. What could cause this?
Old Jan 31, 2017 | 12:11 PM
So so so many things. These cars are getting older. I have had 3 myself and living with them showed me more than working on them. It's a long intake tract pre and post turbo. Lots of lines, hoses, valves and solenoids to check. Then the dirty throttle bodies, gaskets and more let alone different hardware. Even totally stock after a while they can smoke on start up, hick up here and there and they don't love load at low rpm. That said they are amazing cars and should for the most part run pretty well with a good set up so there is lots to check and make the car better.
Old Feb 1, 2017 | 11:07 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
of corse it is not possible to repair the car remote.... have you ever try do run the car without maf ? idle problems and hick up often are maf problems (or vac leaks at the long intake) if your car runs at idle good without maf, it could be a problem at this points ...this test is not expensive and quick done
Old Feb 1, 2017 | 11:23 AM
Gixxed_Spyder's Avatar
Gixxed_Spyder is infamous around these parts
Annoying hesitation, like a quick dead spot around 1500-2000rpm only on a light throttle application. No vacuum leaks, no boost leaks, no codes. Cleaned the TB also.
I noticed it goes away when I do the throttle plate adaptation, works fine a minute or so. Then comes again.
Should I try new throttle body? Any advice?
Cheers.
Had this exact issue for years on my tuned x50. Fixed all the boost leaks, and still, no dice. I finally bit the bullet and got the Cobb Accessport, had it tuned - problem went away. Granted its only been 3 days, but thats 3 days with ZERO hesitation / surging. I cannot reproduce that behavior...so far I'm a happy camper!
HTH,
Deepak
Old Feb 5, 2017 | 10:40 AM
acs370's Avatar
The ignition angle sways up/down when the hesitation occurs.
