is an OEM Bosch TB possible for $238.00?!
Old Feb 20, 2018 | 11:11 PM
'02996ttx50's Avatar
Originally Posted by boyg
Oh I see, thanks for the reply.
I do have a spare MAF btw, it just acts up throwing P0102 maf code and then P1507 (I was confused on your P0507). Idle was not stable, car restarted, PSM ABS lights off and performs normal again, I am lost anyway.
gave ya what i had. problem is ( vis a vis diagnosing ) is obd codes are often generic and LEAD to "causes", as opposed to actual pinpointing. again, my TB related codes ended up being just a bad MAF. GL with it!
Old Feb 21, 2018 | 03:00 AM
Atrox's Avatar
Atrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud of
Indeed the 01-05 996tt and like year boxster use the same identical throttle body.
If if you look here you will notice that the 996tt tb’s all have 986 as first part code number. Mysteriously the boxster part code looks nothing like this. I just ordered a “boxster” tb from Auto Atlanta this week. I will post pictures of new vs old.
Old Feb 21, 2018 | 05:14 PM
boyg's Avatar
boyg is just really niceboyg is just really niceboyg is just really niceboyg is just really niceboyg is just really nice
Fyi, cheapest I can find is from UK, if you dont mind to order overseas...
http://www.design911.co.uk/fu/prod13...T-98660511501/
Old Feb 21, 2018 | 09:46 PM
i found the OEM bosch ( as atrox notes and same as the 986 part ) for about 300 US iirc? before i found i didn't need it. far less than 317 quid.
Old Feb 22, 2018 | 07:11 AM
Atrox's Avatar
What’s confusing is how the tb on top has same part code, but looks completely different.
Old Feb 22, 2018 | 07:12 AM
Atrox's Avatar
What’s confusing is how the tb on top has same part code, but looks completely different. They turned it.
Old Feb 22, 2018 | 09:22 PM
captain obvious says: anytime you purchase a part from an internet source without an EXACT corresponding part#? dont "click" until they confirm compatibility.
