is an OEM Bosch TB possible for $238.00?!
Old Mar 13, 2017 | 09:29 AM
'02996ttx50's Avatar
I have P0507 codes ( idle high etc ) and its not a vac leak, so the next obvious item is a faulty TB and since it was swapped out as a spare a few years back, I'm not gonna bother cleaning it, just gonna replace.
my question has to do with this pricing! $238.00 for a NEW(?) Bosch on Ebay?!
by chance has anyone ever bought this TB before? it's an eBay seller and they claim its a NEW Bosch ( which pelican lists for $1200.00+ Porsche OEM branded is $1300.00! ) so before i pull the trigger i just wondered if this pricing seems even feasible. i called them, they confirm it's a NEW OEM part.
the part number is correct ( its the same TB as in a 986 boxter ) part # 996-665-115-01
http://www.ebay.com/itm/New-Genuine-OEM-Bosch-Throttle-Body-For-Porsche-911-Boxster-Cayenne-Cayman-/302122129346?fits=Make%3APorsche&hash=item4657e1d7 c2:g:EpsAAOSwal5YIjFt&vxp=mtr
any help/advice is appreciated. TIA.
Old Mar 13, 2017 | 09:38 AM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
Wow not reman?
Old Mar 13, 2017 | 09:43 AM
32krazy!'s Avatar
just remember that the oem t/b is a boxster t/b nothing special 68mm. the one you listed doesnt look tlike the correct t/b heres the part # you need
98660511501
Old Mar 13, 2017 | 10:17 AM
98660511501
yeah steve thx.., i recognize its the same part 986/996 but this "seller" part is listed as OEM NEW and they list the part as the 665-11501.
here's the bosch part confirmed as you say... # 986-605-115-01-M114. maybe this is the issue I'm having. but when i called they confirmed it was compatible and the 996/986 TB!
right brockster!? doesn't seem possible!? and why i'm asking lol.
now I'm "afraid" to take their word for it being correct". no way a new OEM is 238 while everyone else wants 1200! rats. ok, thanks..
here's their "compatibility" chart: notice it says OK for 2005 Turbo but no other 996 turbo is listed? that can't be right!?
with Electronic Thro... 2005 Porsche 911 Carrera 4S Coupe 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2005 Porsche 911 Carrera Convertible 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2005 Porsche 911 Carrera Coupe 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2005 Porsche 911 Carrera S Convertible 2-Door 3.8L 3824CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2005 Porsche 911 Carrera S Coupe 2-Door 3.8L 3824CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2005 Porsche 911 GT2 Coupe 2-Door 3.6L 3606CC H6 GAS DOHC Turbocharged
with Electronic Thro... 2005 Porsche 911 GT3 Coupe 2-Door 3.6L 3606CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2005 Porsche 911 Targa Convertible 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2005 Porsche 911 Targa Coupe 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2005 Porsche 911 Turbo Convertible 2-Door 3.6L 3606CC H6 GAS DOHC Turbocharged
with Electronic Thro... 2005 Porsche 911 Turbo Coupe 2-Door 3.6L 3606CC H6 GAS DOHC Turbocharged
with Electronic Thro... 2005 Porsche 911 Turbo S Convertible 2-Door 3.6L 3606CC H6 GAS DOHC Turbocharged
with Electronic Thro... 2005 Porsche 911 Turbo S Coupe 2-Door 3.6L 3606CC H6 GAS DOHC Turbocharged
2005 Porsche Cayenne Base Sport Utility 4-Door 3.2L 3189CC 195Cu. In. V6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2004 Porsche 911 40th Anniversary Edition Coupe 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2004 Porsche 911 Carrera 4 Convertible 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2004 Porsche 911 Carrera 4 Coupe 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2004 Porsche 911 Carrera 4S Convertible 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2004 Porsche 911 Carrera 4S Coupe 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
with Electronic Thro... 2004 Porsche 911 Carrera Convertible 2-Door 3.6L 3596CC H6 GAS DOHC Naturally Aspirated
how can i determine what part the 996-665-115-01 when it appears to require the 98660511501. this is the dilemma. thanks though....
Old Mar 13, 2017 | 10:34 AM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
Sounds like the perfect excuse to swap out the plenum with an SRM and 74mm TB upgrade
Old Mar 13, 2017 | 10:36 AM
I've already got the 68 ipd. happy camper.
now i need a new TB. i don't want the larger 74 as i prefer the mid range grunt.
this seems to be.. an eBay return/hassle waiting to happen. it can't be correct! so I'm gonna pass. "if it sounds too good to be true"?... lol
thx all.
Old Mar 13, 2017 | 10:45 AM
BauerR's Avatar
http://www.new-part.com/
Check to see if the vendor has a phone number you can call. I recently had to return a part i purchased for my 928 to an eBay vendors and it was a very pleasant experience.
See if you can find the part through them.
Old Mar 13, 2017 | 10:51 AM
thx, i called them and they said it will fit! its actually in SoCal so if had to return at least it isn't romania
here are the part numbers as listed on their eBay listing which i've highlighted below.. it seems to be the same! w t f. i just don't see how its possible. they are min $1000/1200 EVERYwhere else....
Other Part Number: 996 605 115 01 , 0 280 750 474 , Manufacturer Part Number:
99760511501 , 99660511501 ,
Warranty: 1 Year Interchange Part Number: 0 280 750 474, 0280750474, 996 605 115 01, 99660511501, 997 605 115 01, 99760511501
here's from the vendor you suggested:
Porsche Boxster 05-06 Throttle Valve Assembly Throttle Body + Seal BOSCH New
Brand:
986 605 115 01 / 996 110 319 00
Part #:
98660511501 / 99611031900
Other Part #:
BOSCH
Other Part #:
$662.33
the 996 part numbers appear to be "different" while the 986 number is the same? ugh.
Old Mar 13, 2017 | 11:51 AM
32krazy!'s Avatar
ask them for the exact part # off the t/b they would ship to you. run it thru autoatlanta and see what pops up
Old Mar 13, 2017 | 01:43 PM
will do. in the meantime my pal is gonna bring a spare to swap in so i can be sure its the tb before i throw a new one at my issue. but better a 238 throw than 600-1200! but yeah, i'll ask them to confirm pre-ship ( they did confirm over the phone ! ) I'm just in disbelief mode being the "trusting" person that i am that a 628 ( cheapest i could find elsewhere..) part could really be the same at $238! plus its probably a pita to return sh*t to an eBay seller if necessary.
thx again.
( btw ) this IS the correct prt # 99660511501
Old Jan 22, 2018 | 05:13 PM
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
Did you get this throttle?? is it a Bosch?
thx again.
Old Jan 22, 2018 | 08:57 PM
no, never did. thought it was the tb, but turned out not to be. no issues since. only thing i learned again, is don't throw parts at a problem. since i didn't need a new tb. glad i waited.
Old Feb 19, 2018 | 08:06 PM
boyg's Avatar
boyg is just really niceboyg is just really niceboyg is just really niceboyg is just really niceboyg is just really nice
I have got the same code recently, I did clean the throttle couple months ago, so may I ask what did you replaced finally? As I searched, it was fuel filter in your case as mention in another tread? Thanks.
Old Feb 20, 2018 | 11:01 PM
are you sitting down? after all this back then.. it was the MAF! i didn't trust my EXPERT bud's advice.. so, before i threw a TB at my issue? i threw a bosch 124.00 at it. 1.3 steady since
Old Feb 20, 2018 | 11:06 PM
boyg's Avatar
Oh I see, thanks for the reply.
I do have a spare MAF btw, it just acts up throwing P0102 maf code and then P1507 (I was confused on your P0507). Idle was not stable, car restarted, PSM ABS lights off and performs normal again, I am lost anyway.
