Clutch chatter
Old May 31, 2017 | 01:20 PM
Kriss16's Avatar
Kriss16 has a spectacular aura aboutKriss16 has a spectacular aura aboutKriss16 has a spectacular aura about
Clutch chatter
Installed a new flywheel and a sachs 890nm kit (without springs) and now getting clutch chatter.. Not bad cold, but really enoying parking it when hot, especially in reverse. Got approx 70 miles after installation now
Anyone with good suggestions?
Got a new master, new gear mounts and new rss engine mounts..
Can it be the accumulator?
Can an accumulator with worn internals fail to absorb the pulsations of the hydraulic pump/assist? So in that case cause the chatter?
Reservoir front an back are at stabil levels..
Old May 31, 2017 | 01:50 PM
s65e90's Avatar
s65e90 is infamous around these parts
Put a sprung disc in it.
Old May 31, 2017 | 06:39 PM
'02996ttx50's Avatar
i run sachs oem parts with a gt2 unsprung disc and no chatter. make sure the parts are all compatible with a new dmfw cos it sure isn't the accumulator.
Old Jun 1, 2017 | 09:43 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
my car chatters in hot like crazy, im on light flywheel as well, I don't mind.
Old Jun 1, 2017 | 02:12 PM
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
What exactly do you mean by clutch chatter? Perhaps you are hearing harmonics from the engine because you have a SMLWFW? If that's the case, then it is what it is it is the nature of the beast (but worth it imo). This would NOT be an accumulator issue. Does it go away w/ clutch pedal depressed? If so then it is exactly what I stated.
Oh - and don't forget to log about 500 miles on your setup before hammering it....need to break everything in.
Old Jun 2, 2017 | 07:36 AM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
Miss installed needle bearings in the fork can cause chatter also.
Old Jun 2, 2017 | 07:42 AM
BMiller33's Avatar
I just had the worst flash back ever.....GOD that assy in-situ was a F'N nightmare
Old Jun 2, 2017 | 08:23 AM
z06801's Avatar
I had a "pro Porsche race shop" at my local track install my freshly rebuilt clutch and trans and they didn't put the whole assembly on one side not even the race that the bearing rest in. Had terrible chatter especially in reverse. They tried to blame it on my light fly wheel. The throw out bearing ended up pulling though the pressure plate stranding me.
Old Jun 2, 2017 | 09:20 AM
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
Im running sachs "2.5" with solid disc....no chatter.
Old Jun 2, 2017 | 10:06 AM
Slider's Avatar
Using higher RPM when engaging will allow you to smooth it out. I have an un-sprung clutch as well. Chatter will reduce a little over time. (providing none of this is an install issue)
Old Jun 2, 2017 | 01:58 PM
^ ya, one hour of wrangling into place, and two hrs for the fork lol
Old Jun 4, 2017 | 08:22 PM
Originally Posted by 32krazy!
Started at 8:30 am and 2 hrs later trans is in and clutch fork installed and secured. Need to button up a few things but the hard part is done!! ðŸðŸðŸ
proving only that practice really can make perfect. job well done.
Old Jun 5, 2017 | 07:29 AM
btw, is that the "built" gearbox from randy's car? i seem to remember that was one thing for sure he did correctly. but its been a awhile..
either way, you must have that thing pretty well sorted by now. have a good summer ( and beyond ) with it!
Old Jun 5, 2017 | 01:00 PM
yes it was a built box. 3,4,5 syncs blown reverse broken. sent it to a shop that originally built it and they clocked the syncs wrong and never mentioned 5 synchro was gone or reverse was broken. after 2 times at that shop i sent it to tim941nyc for yet another teardown to see whats wrong. now has 997gt2 1,2,3 gear sets with 4,5,6 in oem gearing all with steel syncros and a new reverse.
nice! are you running that sqs he bought? thats a pice of work no doubt..
Old Jun 5, 2017 | 01:56 PM
probably just as well.. i've never fully understood the mechanics of that sqs unit anyway.. it's pricey too
well again, GL w the wrapping it up and hope you get in some good runs this summer. cheers.
