How many hp can 2.5" handle?
Old Jun 4, 2017 | 01:27 AM
acs370's Avatar
acs370 is infamous around these parts
Hi. Which kind of power levels you guys are running with 2.5" exhaust?
I have now straight 2.5" pipes when the flaps are open. Is it good for up to 650 hp?
Old Jun 4, 2017 | 06:24 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
If your turbos arent able to reach the programmed boost pressure, you will know. Its a tight call.
Old Jun 4, 2017 | 08:16 AM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
Should be ok for 650hp, but 3" will run better
BLKMGK's Avatar
To not make set boost you would have to have really hit the wall with restriction, I'd think a flow restriction would hurt power long before that. You could probably do some math to figure out flow. Do you have any reason to believe you've hit a choke point with your existing setup? The flaps and mechanism will probably cause some restriction even opened so consider that. Pretty sure my exhaust is 3inches so I'm not much help with real world data I'm afraid...
Old Aug 2, 2017 | 09:12 AM
johnspeed's Avatar
2.75 " needed.
Old Aug 4, 2017 | 05:42 PM
you need to open it up and let it breath
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
