suspension problem - bad 'swerving' in back
Old Jan 22, 2006 | 08:16 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
car is lowered on JICs (maybe 10k miles on them?) set to the softest setting right now. 19" wheels w/ PS2s. Stock sway bars.
here are a few conditions where i feel the back end 'swerving' on me; i'll try to give as much info as possible in hopes that someone might figure something out:
1. pitch steering wheel back & forth quickly
after doing this, you can feel the back wobbling/swerving for a half-second. it kinda feels like a flat tire (yes, i checked the air.)
2. hit a big highway undulation
you can feel the back end wobble slightly after hitting a highway undulation doing 75mph+
3. high speed (130mph+)
car is not nearly as solid as it once was - you can feel the wobble a bit - probably just a sympton of #2 above.
i had a broken drop link that we fixed. while i understand the 19s may not give the best grip (18s are in my future), i can't believe they are causing the car to act like this (and it wasn't like this when i first got it 2 months ago.)
- bad coiliver? even w/ such low miles on them?
- bad sway bar? (what does that even mean? broken? it isn't...)
- anything else?
while i love this car, the problems are getting very annoying.
thanks,
chuck
Old Jan 22, 2006 | 08:37 PM
FAT-911's Avatar
FAT-911 is infamous around these parts
Check your sway bars and links again, the links can break very easily, also check that the helper spring has enough tension that it sits firmly against the spring, also check that the lower brackets are in place correctly and ensure that all the associtaed nuts and bolts are tight.
Old Jan 23, 2006 | 09:05 AM
Joe Weinstein's Avatar
It also sounds like one shock at least is not damping.
Old Jan 23, 2006 | 09:15 AM
ebaker's Avatar
ebaker is infamous around these parts
Check the rear toe-in.
Old Jan 23, 2006 | 09:35 AM
I just reread that you have your shock on the softest
setting. When you say 'setting' that implies there is only
one setting, which is usually rebound damping. It may simply
be that you need much more damping. Try setting
it to midway between full soft and full hard.
Old Jan 23, 2006 | 02:19 PM
Ruiner's Avatar
My JICs are set for 8 rear/6 front and are perfectly stable.
Old Jan 23, 2006 | 03:26 PM
carendt242's Avatar
i don't think it's the settings as it definitely didn't do this when i bought the car 2 months ago.
i will play w/ putting each of the rears on the highest setting to see if there's any difference.
no time to check everything mysef so will take it to sharky... i'm beginning to think i should just rent a space in his garage since i've had no such luck w/ 'porsche reliability...
- chuck
Old Jan 24, 2006 | 01:41 AM
Turbo Fanatic's Avatar
I ditto alignment (or something loose) as the culprist.
Old Jan 24, 2006 | 02:31 AM
03-turbo911's Avatar
Senior Member
Also check the tires, wouldn't hurt to double check everything.
Old Jan 24, 2006 | 07:04 PM
spidey's Avatar
spidey is infamous around these parts
Alignment and wheel weights ??
Old Jan 26, 2006 | 03:40 AM
Cary Eisenlohr's Avatar
Cary Eisenlohr is just really niceCary Eisenlohr is just really niceCary Eisenlohr is just really niceCary Eisenlohr is just really nice
Jack the car up in the back so that the rear wheels are off the ground. Grab the tire at 12 o'clock and 6 o'clock and try to move it back and forth as if you were testing for a lose wheel bearing. Then repeat the same at 9 o'clock and 3 o'clock. If there is any movement (clicking or clunking) it could be a bad bushing in one of the suspension links. Also, you may have hit a good bump recently and that can cause some toe out on one side and that will give that feeling. Also, as Joe pointed out, take a look at your shocks to see if there is any fluid leaking and if there is you might want to test them as well. good luck
Old Jan 26, 2006 | 10:36 AM
sharkster's Avatar
- chuck
LOL poor chap... Cary makes some good points however there's no real noise or even clues from the braking about a bearing Also, last time we had the spare on there so it was hard to drive it at all. Now with the right tires we'll give it another shot... We'll look for the usual stuff including leaks. However before you did get a spare your tire wear was pretty crazy on that one tire in the rear so I guess it could have been "knocked" off of a good alignment.
Old Jan 26, 2006 | 11:01 AM
TT Surgeon's Avatar
Your springs probably settled a bit too, that will cause some toe out. Make sure you're not set too low, as you will be getting bumpsteer as the shock bottoms out.
Old Jan 27, 2006 | 09:13 PM
HZ@RSC's Avatar
HZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to beholdHZ@RSC is a splendid one to behold
Check the Spindle Bearing or Spindle itself.. Sounds like you are talking about an alignment issue Too much toe in would result in exactly that behaviour
Old Jan 27, 2006 | 09:25 PM
sharkster's Avatar
Oh yeah.. alignment is an issue- that much we know. Easy to fix that. But man this JIC-equipped car on 19s feels just like another one we had. It bounces everywhere in the front.. We'll look at it tomorrow and get her sorted
