Cleaning exhaust tips
Old 07-23-2017, 05:11 PM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
So I just installed some new exhaust tips and my new speedtech 3" x-pipe. Like an idiot, I left the plastic wrapping on the tips while I installed it to avoid scratches. I started up the car and they insta-melted to the pipes. Any bright ideas on how to remove the scorched plastic off polished stainless?
By the way the exhaust sounds amazing, best move I've made with my car to date.
Old 07-23-2017, 05:27 PM
jdexter's Avatar
ID:	480581Click image for larger version
Old 07-23-2017, 05:47 PM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
Then final buff with Mothers billet polish.
Old 07-23-2017, 07:58 PM
06Turbo's Avatar
06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future
I personally would try acetone first before taking basically steel wool to the polished surface. May or may not work, but it may save you the trouble of trying to polish out fine scratches.
Old 07-23-2017, 08:05 PM
Road King's Avatar
Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !
Also, maybe give Goo Gone a shot, it's mild solvent that may help.
Old 07-23-2017, 08:12 PM
jdexter's Avatar
When cold it's hard as a rock, but if I get it hot its soft and can be scraped off, but it melts the things I am using to scrape. I'll try some solvents this week. Need something that melts plastic...
Old 07-23-2017, 08:25 PM
Stebo's Avatar
Stebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond repute
Silicone has a pretty high melting point and is used for spatulas and other food prep scrapers. Maybe grab one from Wal-Mart or target before going the chemical route.
Could also use controlled localized heat via propane or mapp gas torch rather than turning the car on. Be careful obviously and don't flame your bumper!
Old 07-23-2017, 09:22 PM
'02996ttx50's Avatar
ouch. same thing happened to me when i covered my car with the pipes still hot with a pic outdoor cover. i tried all manner of things, and they'll never look the same..
just buy new tips.
Old 07-23-2017, 10:05 PM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
Try oven cleaner.
Old 07-24-2017, 12:52 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
I use nevr-dull.
Old 07-24-2017, 03:56 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
oven cleaner...(use the same after the grill season...smile)
Old 07-24-2017, 05:12 AM
rickw30's Avatar
rickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud of
Try MEK (Methyl Ethyl Ketone). Get it at Lowes or Homo in the paint depth. I have also used brake fluid in the past.
Old 07-24-2017, 11:04 AM
Atrox's Avatar
Atrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud of
homo in the paint depth what pipes you getting cleaned?
Old 07-24-2017, 04:03 PM
rickw30's Avatar
I don't know what kind of chism you have on your pipes, but MEK always cleaned mine.
Old 07-24-2017, 04:19 PM
Slider's Avatar
I would just use #5 paste (white) with a metal polisher. They will look absolutely new when you are finished.
