Cold start engines chirp.
Old Jul 25, 2017 | 11:40 AM
kamkaz's Avatar
kamkaz is infamous around these partskamkaz is infamous around these parts
I drive the car every couple of weeks. The last few start ups this little chirp has started. I'm use to hearing this when I start the car after a car wash but not on cold/dry starts.
Take a listen:
You can hear it at the 7 second mark.
Old Jul 25, 2017 | 02:44 PM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
How old is your drivebelt?
Old Jul 25, 2017 | 03:24 PM
kamkaz's Avatar
Good question. I'll have to check the service logs.
Old Jul 25, 2017 | 05:37 PM
r6vr6's Avatar
r6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to all
The belts are cheap ($25 or so) and not too bad to change. Throw one on and see if it goes away likely time for a new one for preventative measures any way.
Jferrante's Avatar
Jferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant future
Yea pull off the drive belt and start the car - it might be an idler or one of the pulleys - thats an easy way to isolate it if it doesn't it on every start up. just don't run the car too long with the belt off for obvious reasons
Old Jul 25, 2017 | 06:09 PM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
battery is old and at low voltage, lima belt slips for a second
look at the rearlights during starting and hear low cranking rpm....
maybe change both and be happy
Old Jul 31, 2017 | 09:46 AM
kamkaz's Avatar
Thanks everyone. I'll do both at the next service. I'm sure it will fix it.
Old Jul 31, 2017 | 10:23 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Someone on the facebook group had a similar issue that wound up being the turbo blades rubbing on the housings because the bearings were worn. Check for that if it isn't the belt.
