Installed RSS motor mounts.
Old Aug 29, 2017 | 09:52 PM
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
Very true...I might just do that.
Originally Posted by '02996ttx50
why not "split the difference"? and go with semi's? great compromise, that'll add nvh but easily manageable for a street car.
Old Aug 30, 2017 | 09:36 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
That's my next mod! on the list - i picture my motor mounts as my front upper strut mounts, old and saggy like an old bed
Old Aug 30, 2017 | 06:20 PM
'02996ttx50's Avatar
Originally Posted by VAGscum
Since I have installed the mounts it has been difficult to drink coffee with all the well planted canyon carving I have been doing. How's that??
perfect lol
Old Aug 31, 2017 | 04:09 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Originally Posted by Slider
OK, enough from you guys - who has had a bad experience? Anyone?
Semisolids (engine and transmission), LWFW and straight cut 3rd gearset, have to use earplugs...but it's worth it...
Old Aug 31, 2017 | 08:18 AM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
I installed the Porsche RS mounts and can now hear more transmission whine. That's the only negative I can see.
Old Aug 31, 2017 | 05:54 PM
^ yeah, thats that weird "added nvh" going from oems to solids or even semi's we all "hear". i call it "drivetrain" whine instead of "trans whine" because thats and I've had that! but yeah, 6 of one, 1/2 dozen of another ! they sure tighten up the car though!
Old Aug 31, 2017 | 07:04 PM
VAGscum's Avatar
Yup. It is noisy. Then add hard transmission mounts, solid metal motormounts and a noisy cup LSD 😳
Old Sep 1, 2017 | 10:52 AM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
I picked up some noticeable gear whine after adding hard trans mount and cup cables.. seems to be most noticeable in 5th gear at lower rpm, or in 1st gear at parking garage/parking lot speed.
Old Sep 3, 2017 | 11:29 AM
sid350's Avatar
sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !
I got the wevo engine mounts no complaints👍
Old Sep 5, 2017 | 12:41 PM
Slider's Avatar
So, the Wevo do not add to noise?
Old Sep 5, 2017 | 12:49 PM
sid350's Avatar
Not really. I got a bbi exhaust and Carbonetic triple so that noise pretty much drowns everything out.
Old Sep 5, 2017 | 02:10 PM
Third-Reef's Avatar
I think any aftermarket engine mounts are going to add noise. Now if you have an aftermarket exhaust you may not notice the added noise. That was the exact case with mine. Put in the Porsche RS mounts while i had the Kline exhaust on and maybe i could hear a little more noise. Switched to the stock exhaust (for noise restrictions at LAguna Seca) and i had to change the oil in my transmission because i thought i had a bearing going out. 5k miles and a track day since then and it has not changed, so my transmission is not going out and it sounds like a race car
Old Sep 5, 2017 | 02:20 PM
wevo's add nvh. but well worth it.
Old Dec 19, 2017 | 04:56 PM
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
I just got my Torque Solutions engine mounts in. Just slightly more NVH, but I enjoy the added control of secondary motions. Everything feels tighter without the secondary motions coming from a flexy engine mount.
That said, the TS engine mount rod seems 1/2 shorter than the stock mount, when fully threaded into the engine mount body. While not an issue installing, I'm concerned this might be an issue when it comes to servicing the car. Often times, various maintenance of things require lowering the motor. I don't think I can control whether the nut backs off or the threaded rod backs off, and to what extent, such that I can be confident the motor is still supported?
Anyone else experience lowering the motor with these aftermarket mounts?
Old Dec 21, 2017 | 08:54 AM
Johnny DB's Avatar
I'm likely going with the Porsche RS mounts
