Abs/psm Lights
Old Jan 29, 2006 | 11:08 AM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Abs/psm Lights
Picked up my tt after the gtr640 install yesterday. I have not boosted the car yet because the turbos are being broken in first and I have stock boost hoses (mechanic said the stock ones will blow off?). The new hoses were suppossed to get here yesterday but they were a no show.
Well when the car was started the first time the abs and psm lights came on. They will not go off. I read the code: P1656 manufacturer control auxillary input auxilliary output/manufacturer controlled computer and auxilliary outputs.
Any help
Jags
Old Jan 29, 2006 | 01:06 PM
MBailey's Avatar
Iam not familiar with that code but given the recent history of the car I would guess a hose leak...
Old Jan 29, 2006 | 01:13 PM
trev0006's Avatar
trev0006 has a spectacular aura abouttrev0006 has a spectacular aura about
I just fixed my car that had a hose leak also with psm abs lights, originaly I thought it was the MAF but it was the turbo to the intercooler hose.
Old Jan 29, 2006 | 01:15 PM
ebaker's Avatar
ebaker is infamous around these parts
Here's what the OBDII manual says
P1656
0-197
page 1
p1656
Printed in Germany, 2000
0-197
P1656
575 Coolant shutoff valve - open circuit
Diagnosis conditions
Engine running
Battery voltage greater than 7 V
Coolant temperature greater than 90 °C or ATF temperature >
85 °C
Possible fault cause
Wiring harness
DME control module
Affected terminals
Terminal IV/40
Diagnosis/troubleshooting
Work instruction Display OK If not OK
1 Check coolant shutoff
valve for continuity
Remove connector of coolant
shutoff valve
Measure resistance at coolant
shutoff valve between Pin 1 and
Pin 2
Approx. 20 - 30
Step 2
Replace coolant
shutoff valve
End
2 Check wiring from DME
control module to coolant
shutoff valve for continuity
Connect special tool 9637 to
wiring harness (DME control
module plug)
shutoff valve
Measure resistance between
special tool 9637 plug IV Pin 40
and coolant shutoff valve plug
Pin 2
0 - 5
Step 3
Repair wiring harness
End
3 Replace DME control module
Step 4
4 Perform adaptation
Switch on the ignition
Wait one minute
Do not press the accelerator
Switch off the ignition for at
least 10 seconds
Read out the fault memory
End
DME 7.8 DME 7.8
P1656
0-197
page 2
p1656
575 Coolant shutoff valve - below limit
Engine running
85
°C
Wiring harness
DME control module
Affected terminals
Terminal IV/40
1 Check wiring from DME
control module to colant
shutoff valve for short to
ground
module plug)
shutoff valve
Pin 2
Step 2
End
2 Replace DME control module
Step 3
3 Perform adaptation
Wait one minute
least 10 seconds
End
DME 7.8
Old Jan 29, 2006 | 02:02 PM
jags911tt's Avatar
Thanks guys. I just got off the phone with Stephen at AI and theh gt2 program was loaded onto my ecu instead of the 996 tt program. So I will resend the ecu to AI on Monday and have the correct file installed. This will take care of the code and the lights. Now I'm just waiting for the silicone boost hoses.
Jags
AuZZie
Sep 2, 2015 04:26 PM
Airbus Driver
Cayenne 958
Sep 2, 2015 12:50 AM
GSR Autosport
Aug 26, 2015 05:20 PM
