Cold weather --overboost?
Old Nov 18, 2017 | 07:47 AM
acmf74's Avatar
acmf74 is infamous around these parts
My car is all stock and during the summer warm months I could reach about 7 to 8 bar.
Now that the cooler air has settled in my car hit 1.5 bar?
Can this be a symptom of a boost leak or bad MAF?
Thanks.
Old Nov 18, 2017 | 08:10 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Get it checked out, I blew up overboosting in the cold with K24 billets.
Old Nov 18, 2017 | 08:18 AM
Slider's Avatar
Something isn't right... I'm in Canada and I don't get that kind of boost in the winter.
... although, it's tough to find a sticky enough surface to support that kind of acceleration in the winter too - the tires will cut loose before you can get there.
Old Nov 18, 2017 | 10:08 AM
wross996TT's Avatar
On a stock car, that is way too high. Besides pressure testing the system, check the waste gates.
Old Nov 18, 2017 | 10:55 AM
jpflip's Avatar
Last time I work on a car with overboost, one of the sense line coming from the intake and going to the N75 valve was disconnected.....
Old Nov 18, 2017 | 11:15 AM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
Lower the engine and check all lines around N75 and to fuel pressure regulator. Boost leak test!
Old Nov 20, 2017 | 11:28 AM
acmf74's Avatar
Sounds like it may be some-kind of leak...
Funny thing its only in the cold temps it acts up.
TIA
