GT2 Slave Conversion - Slave Failure
Last winter I dropped my engine and trans to install a Wavetrac TBD, pin coolant fittings and complete the drill and tap GT2 conversion.
I've been running the upgraded sachs clutch , PP and LWFW for several years. These parts were in great shape except the TO bearing which was replaced.
I did all the work myself (except the wavetrac) on my lift. Followed the great DIY here and installed a new master, rubber hose, slave and fork. I clearanced the trans housing to ensure the fork would not bind.
I was concerned about the slave failing due to residual pentosin in the system (as experienced by several others). Used my motive bleeder and flushed three containers worth of soapy water thru the old master and green hard line into a bucket, followed by 2 liters of new DOT3. The new master, rubber hose and slave were installed after the flush cleaning. Ran some new fluid thru the system, done.
The conversion was working as advertised, one of my favorite upgrades.
Decided to go for a drive last weekend. A few miles out the clutch pedal hits the floor. I thought I was home free after over 6 months and several thousand spirited miles.
Dragged her home and up on the lift. No leaks or weeping, full reservoir. Has to be the master or slave. I will be pulling the slave to make sure the rod did not come out of the slave.
Has anyone else experienced a GT2 conversion slave failure after a few months of good operation? Any thoughts on the cause of failure ?
you need to use dot4 on the gt2 slave conversion. many have suffered the consequences of either trying to re-use ch11s after the swap. as i understand it. flush and rinse and repeat to ensure there is zero pentosin remaining in the system. then fill with dot 4. you might wanna change upgrade the cap up front also to specify dot4. as a reminder.
extremely corrosive and flammable.
The slave is out, relatively simple procedure vs. accumulator set-up.
Rod is sitting properly in the slave, ran the inspection camera in and see the fork is also place. No visible leaks, fluid level good was as mentioned before. Not sure how to test if the slave has failed without replacing it.
I'm failing to see how there was any pentosin left in the system. The only section that could have had contained any was the green line which was flushed with several liters.
There are several examples of owners replacing the slave right after this conversion. The theory is usually residual pentosin. It would be good to identify a solid cleaning procedure that eliminates a redo.
