996TT exhaust
Old Dec 9, 2017 | 11:45 AM
rickw30's Avatar
rickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud ofrickw30 has much to be proud of
Originally Posted by BauerR
My thoughts have always been, if you can't afford to do it right, leave it alone.
+1.. You are correct !
Old Dec 10, 2017 | 06:01 AM
jason952's Avatar
jason952 is infamous around these parts
Kline catless ftw, I run the j shaped o2 foulers and no CEL
Old Dec 11, 2017 | 03:43 PM
jpflip's Avatar
Jason can you tell me which fouler you are using? I got a Kline also but a P0430 fault since installed ;-( I got some extensions but too long to put the 02 sensors...I guess you got the 90 degrees ? If possible where did you get them...Thanks for the information....
Old Dec 11, 2017 | 04:51 PM
jason952's Avatar
Amazon Amazon
I am running the smallest restrictors.
Stock tune, Cobb upload soon
Cheers
Old Dec 11, 2017 | 05:38 PM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
O2 extenders did not work for me and I tried nearly every configuration
Old Dec 11, 2017 | 05:44 PM
jpflip's Avatar
With a Kline or another type? Did you had the P0430 fault? That's what I got on the right bank only....
Old Dec 11, 2017 | 07:10 PM
BauerR's Avatar
I had P1155 and yes, right side.
Speedtech 3" xpipe exhaust
Old Dec 12, 2017 | 09:27 AM
SamboTT@ByDesign's Avatar
Those Vibrant 11619 spacers are great.
Old Dec 12, 2017 | 09:36 AM
jpflip's Avatar
Order some yesterday! I hope it will fix this fault I am living with since 2014 ;-) The other solution of replacing both cats (as per Felix) with new improve one is a bit too expensive for me
Old Dec 12, 2017 | 04:40 PM
LukesportsmanX's Avatar
LukesportsmanX is a splendid one to beholdLukesportsmanX is a splendid one to beholdLukesportsmanX is a splendid one to beholdLukesportsmanX is a splendid one to beholdLukesportsmanX is a splendid one to beholdLukesportsmanX is a splendid one to beholdLukesportsmanX is a splendid one to beholdLukesportsmanX is a splendid one to behold
If you want "cheap", why not find a "good ole boy" and have him install some pipe and some bullet mufflers. Keep the OEM when you grow tired of drone or can afford a nice set up. That way you aren't doing irreversible mods.
Old Dec 13, 2017 | 10:16 AM
Keep me posted mate. I will do what I can to help as you have been so helpful to others. I have a feeling the spacers will do the trick!
Old Dec 13, 2017 | 10:30 AM
jpflip's Avatar
Thanks !!!
Old Dec 16, 2017 | 08:19 AM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
Stock mufflers are basically worth less so for starters drill out the stock muffler and see how that goes for you. If thats not enough then pick up an aftermarket stock exhaust. Drilling out the stocker adds volume and zero drone and is free so give that a go.
Lots of discussion on it in this thread here, believe it was 15hp increase or so:
https://www.6speedonline.com/forums/...ler-996tt.html
Pull stock tip, ram a 2" hole saw up the exhaust outlet until you drill a hole through, pretty simple. Don't even need to remove the muffler. I did it a few years ago and it it's been enough for me for years now. I take my kids in the car with me so a loud drony exhaust isn't an option.
