New 996tt owner! A few questions too!
Old Dec 16, 2017 | 06:36 PM
David Rohrer's Avatar
David Rohrer is infamous around these parts
Hello, 6 speed!
For some reason my previous thread was deleted? I don't know why.
I'll be brief. Just purchased a 2002 996tt. Fast, beautiful, love it!
Question:
3rd 4th and so on will slip the clutch from 3k-4k then it will catch again.
Transmission is new! GT2 slave conversion, sachs 2.5 with LWFW. All with about 2k miles on them. No leaks. Pressure plate part #99611602751.
k16 billets, 72lb injectors, EPL tune. Makes 500AWHP on a mustang and 570AWTQ. Right now I see about 1.3-1.4 bar holding strong.
Is that pressure plate rated for 700+tq? I don't want to burn up the flywheel or new clutch. Everything catches STRONG when shifting hard through the gears ABOVE 4k rpm. Dynograph shows peak torque at 4.1k which is why I'm thinking it's the wrong clutch set up and only slips that little bit then catches.
MODS: if my previous post shows up for some reason, delete this one.
Thanks.
Old Dec 17, 2017 | 05:56 AM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
I think this is the pressure plate you wanted...
http://www.pelicanparts.com/More_Inf...2-999-764-M410
Also, you may want to check in with your tuner... my understanding is that 1.3-1.4bar is danger zone for bending rods unless you are on race gas or built motor... My car is built very similar
ps - new owner... pics are required
Old Dec 17, 2017 | 06:13 AM
I thought the previous owner must have used the incorrect pressure plate. Sh*t. Well, I left Tony at EPL a message on Friday for a re-tune. This setup should be great for around 650ftlbs from my research. I'm thinking about a much more progressive tune that will ramp up the boost instead of everything at 3-4k RPM. Tony at EPL is who originally tuned the car on this set up so I know he will take care of me!
Old Dec 17, 2017 | 06:29 AM
jdexter's Avatar
nice car man. I'm sure you'll get it figured out.
Old Dec 17, 2017 | 06:34 AM
Thanks man!
Yeah I really love it. 41k miles perfect condition. Right now the car is very driveable, I started reading through the receipts and realized that the 751 (754) pressure plate was installed. It was cold yesterday and that is when I had a clutch slip. The car is really strong, but I am going to turn it down in the mid range. It needs to be much more progressive.
I wouldn't say this thread is "solved" but I think I know what the issue is now since the 999 pressure plate was not installed.
Any other thoughts from readers?
David Rohrer
Dec 16, 2017 01:33 PM
zmt
Nov 9, 2013 08:58 AM
reedickyaluss
Cayenne 955/957
Apr 27, 2012 06:53 PM
ziggy723
Jan 22, 2008 04:00 PM
