Cross Suspension? Anyone know it?
trust me teh 7kg & 10kg is fine... u can just turn up the stifnness i drive my car in la and the roads are bad can feel eveyrthing.. it sucks when u hit an expansion slab on the freeway....
wish me luck ver. 3.0 on the drop links on my car soon hahaha
ver 1.0 broken, ver 2.0 broken im on my 2nd set of ver 2.0 lets se ehow ver 3.0 holds out..
Originally Posted by Ruiner
I have the 7/10kg setup and it is a good bit more stiff than stock; you can definitely feel the difference. However, if you want a true track suspension, you will want to go even harder, that's all. Remember, though, if you drive on the street with ANY harsh suspension, you WILL feel it.
Originally Posted by iLLM3
Yea i know, i drove my M3 stripped with roll cage and slammed on the street, it still wasnt stiff enough! The Porsche on ROW is extremely soft to me, i also want something that will be really good on track, so the 7/10kg setup is more of a street/track combo over the pss9's correct? No need to go stiffer?
Think of the 7/10kg as being more street, but some track.
The 8/12kg as being an even combo of street and track.
Finally, the 10/14kg combo as being less street and more track.
Merek im extremely interested in your suspension you have for sale, but you said you have the "soft" version? Im looking for the most all out, tracky/race like ride.. I had my M3 setup for straight up track and had PSS9's, realized they were too soft for my liking although they handled well, they just werent confident for me, what do you recommend?
8/12kg is their "recommended" setting for street/track.
Originally Posted by vincentdds
Ground Control are much better for the M3. Cross are very simlilar to Ground Control for 996TT IMO.
Ruiner and Vince, thanks so much guys
Martin
Ahhh so here's the info ive been looking for.. Ok Ground Control i know is INSANE for the M3, so if this JIC Cross suspension can compare to that then this is def. for me! Im getting it, so should i just buy the 8/12kg setup, or get his and upgrade to the different springs, or what is it that set's the two of them apart??
Martin
Martin
Martin
I know for sure PSS9 is way soft for you.
Martin
Anyway yea i think you know exactly what i want, and will take your advice
Exactly, did you take a ride in my M3? I think partly it was the seats with all of that cushioning, but for a real stiff, track setup suspension sitting on pillows sometimes wont help
Daniel detailed the car so he didn't want me to drive it in the rain. I will give it a spin when the rain stop. It looks better than his other CSL M3 SC on his site.
I just purchased an '02 996tt in September and am putting the JIC's on. I have owned many track cars in the past and have used Bilsteins, KW, H&R, Moton, Apexi, HKS, and JIC. IMHO, the JIC/Cross with the 8kg/12kg is the perfect combination for a serious enthusiast who wants optimal handling for the street/canyons and will occasionally track the car. Call JIC and speak to John, he has a 996TT and he'll give you the full scoop on which spring rate is best for your needs. I'll also be running these with 19" Kinesis F110's, so the ride is definitely not too harsh for the street with the 8/12 springs.
Your next challenge is to get some curved front drop links so you can use the GT3 adjusable sway bars. I bought a used set made by ScarGO. Racers group used to make them. They were out of stock when I was ready to buy.
