GT2RS transmission upgrade, still 2nd pop out!
Old Mar 10, 2018 | 10:59 AM
acs370's Avatar
acs370 is infamous around these parts
So I got my car finally back from JZM Gulf in Abudhabi.
The box has new bearings, shift forks, GT2RS mainshaft and 1-4 gears, all new steel synchros. Also CMS shift arrester was installed. The mechanic said he shimmed the 2nd gear to engage properly. The 2nd gear shift has always felt like there is something light resistance, not engaging like the other gears. The only things we did not change were the fork rods and drivers. Anyway the 2nd gear pops out on low revs. What is it if it’s properly shimmed?? F@$&%^5**!!!!!!
Old Mar 11, 2018 | 12:35 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Hello bro , since you are in UAE , did u check alpha logic shop ??? They are good from what I heard
Am in kuwait , I built my gearbox locally with Bill Rader parts and installation were fine , please let me know if you need anything ..
Old Mar 11, 2018 | 12:24 PM
acs370's Avatar
Thanks buddy, JZM will open it up once more as a warranty action. Never heard about that Alpha shop, did they build your transmission there?
Old Mar 11, 2018 | 03:53 PM
ysfg35's Avatar
No , I built my gearbox in Kuwait locally , alpha logic should be good shop if your current shop fail to fix the gearbox
Jako
Jul 18, 2014 02:22 AM
602996TT
Jun 16, 2014 01:26 PM
M3CAB
May 12, 2006 09:48 PM
Drew
Oct 5, 2005 06:10 PM
