Switching to 997TT calipers, anything i need to consider?
Old Mar 12, 2018 | 07:45 AM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
So i have been running 350mm discs with stock calipers on spacers.
I figured i should upgrade and now have a caliper set from a 997 turbo lying here.
I recon this is bolt on, but how about brake balance, do i need to change the master cylinder?
The rear calipers has what i believe is aluminium pistons, while the front have steel? with zircon pads, is this right or have i gotten a newer calipermodel for the rears?
Old Mar 12, 2018 | 10:42 PM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
​​​​​​No. The piston area is the same or smaller, depending on the calipers you use (steel or pccb).
Old Mar 13, 2018 | 12:30 PM
Ronny-'s Avatar
Thanks, i believe these are from a steel disc car. The piston sizes are 28, 32 and 38mm
Old Mar 14, 2018 | 05:17 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
You should upgrade the rears too.
Old Mar 14, 2018 | 05:27 AM
Ronny-'s Avatar
The rears are beeing swapped to, hence the question about them having aluminium pistons
Old Mar 14, 2018 | 11:21 PM
I bought the 997 GT3 MkII version. These are right for the zirkon pistons.
SonicKrack
Jun 16, 2010 07:56 AM
Crea
Feb 23, 2010 08:47 PM
WearyMicrobe
Mini Cooper
Sep 5, 2009 07:10 PM
Evolution MotorSports
Apr 7, 2007 02:05 AM
Josh/AWE
Apr 5, 2007 03:17 PM
