New vendor wishing to say hello!
Hello everyone!
Forgive me for being new to forums but I am happy to say that DriverSource, located in Houston, TX is now a vendor with 6SpeedOnline! I also wanted to let everyone know about a couple things we have going and that we have been working on. First, we have a new website for parts sales, www.driversourceparts.com, that currently has parts for Porsche vehicles from 1999 - 2012. My apologies the range isn't bigger as the site is still in it's infancy, but we will be adding steadily over the coming weeks and months so please continue to check back.
Second, is that I am pleased and fortunate to announce the Porsche Billet Triple-Carbon Clutch by RPS Performance Products. Having worked extensively with RPS over the last few years we have developed a carbon-carbon clutch for Porsche 993T/996T/997.1t/GT3 that works in all situations and offers drivability and performance that can't be matched for the price. A little "press release is below", please feel free to visit our website, www.driversourceparts.com, or DM me for any details you may need. Clutches are in stock and are being offered at a discounted price from now through April 17th.
NEW TO MARKET!
DriverSource in Houston, Texas is proud to announce our new, Porsche Billet Triple Carbon Clutch by RPS Performance Products. This is a new design, true Carbon-Carbon clutch that will fit any 993, 996, and 997.1 Porsche Turbo model. Clutch includes Steel Flywheel and all hardware and instructions for installation. Note that it requires use of the short release bearing sleeve on the transmission (available separately).
This clutch is, simply put, the best clutch for holding big power and offering excellent drivability. Smooth engagement and gentle on drivetrain components yet able to hold 1500 ft/lbs of torque, there is nothing on the market that can even come close for the price. Weighing right at 30lbs complete, it is significantly lighter than the OEM dual-mass setup (~47lbs) yet still heavy enough to allow for driving in stop-go traffic without looking like an amateur behind the wheel. There is no shimming required with wear in this clutch unlike some other Carbon-Carbon clutches on the market so you do not need to worry about removing the transmission every 1500-2000 miles to shim your pressure plate for proper engagement. It is also fully rebuildable.
Pedal pressure is comparable to stock and the clutch can be used with either the stock hydraulic assist system or the GT2 style slave cylinder conversion. We recommend using a GT2 style slave conversion for the best feel and consistency when driving but we’re happy to offer recommendations based on your setup. Please visit www.driversourceparts.com to purchase!
NEW TO MARKET!
There is two release bearing guides available, a short and a long one. The short one is for dual-mass flywheel equipped cars and the long one is for cars with a lightweight flywheel like the OEM GT3RS flywheel. The overall "stack" height (flywheel, clutch disc, and pressure plate) is shorter with the GT3RS flywheel so it needs a longer tube to center the release bearing when operating the clutch. Trying to run a long sleeve on this clutch (or a dual-mass) will cause the clutch to not disengage (assuming you can even get the transmission bolted up correctly in the first place).
If you have a dual-mass now, then no need to change. If you aren't sure, then you would want to verify which guide sleeve you have.
Hope this helps!
Hope this helps!
SpedingBMW325i
Northwest
23
Nov 28, 2018 03:49 AM
