Only getting .6 bar under full accel...
Old Feb 14, 2006 | 07:48 PM
mitchmarket's Avatar
mitchmarket is infamous around these parts
I have a pretty modded turbo but can only get it to read .6 bar even under the hardest pulls
Anybody know what this might be happening? Thanks in advance.
Old Feb 14, 2006 | 09:37 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
0.6 bar, seem your TT at lime mode, check if any hose leak or failed MAF.
Old Feb 14, 2006 | 10:16 PM
Ruiner's Avatar
Try punching it at 2500rpm in 5th or 6th gear. See what you get...
Old Feb 15, 2006 | 07:58 AM
No, nothing different in 5-6th gear punching it. Not sure what Lime Mode means up above...
The next time I take it in, I will have them check for hose leaks.
Anybody else have experience with this sort of thing? Thanks in advance.
Old Feb 15, 2006 | 08:05 AM
Ruiner's Avatar
Lime = "limp" mode. He meant to say limp mode.
Old Feb 15, 2006 | 08:18 AM
OK, so what does "limp mode" mean, what causes it and how to I have it fixed? Thanks. :-)
Old Feb 15, 2006 | 08:59 AM
lithium's Avatar
lithium is infamous around these parts
something is tripping the ecu and it goes into safe mode, reset ecu first and see if that fixes it.
Old Feb 15, 2006 | 10:15 AM
marcsanz's Avatar
marcsanz is infamous around these parts
Since we dont know how modded you are, diverter valves are a culprit also.
Old Feb 15, 2006 | 03:05 PM
Thanks. I have Evo Billet diverter valves. I will drop off to my shop next week, along with ya'lls feedback to jump start them.
It always helps to have some insight prior to showing up, it always saves you some $$$ in the long run. :-)
Old Feb 15, 2006 | 05:07 PM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
I have the same problem but it always fixes itselves after a few hours or the next day I have the upsolute chip and stratmosphere diverter valves....My car runs normal for several days and then without any reason I can't get boost above 0.6 bar....I've been told it's a problem with the upsolute chip and they are trying to solve it....
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
