GT2 gearbox oil cooler
Bloody hell, I hope not. The gearbox is virtually junk without it as the oil pump lubricates the whole gearbox. They also use the same pump on recent models, all the 997 GT3's use the same cooler and pump.
Unless you just mean the disc valve and solenoid? I noticed a few of the vacuum lines are NLA, but they're nowt really.
edit: just checked, the disc valve and vacuum change over solenoid are commercial items, so can be had much cheaper without the Porsche tax.
Pierberg vacuum change over valve, PORSCHE: 7PP 906 270, 996 605 123 01
XXX: H72031281, 7.22280.01, 72228001, 7.22280.01.0, 722280010, 7.22280.02, 72228002, 722280020, 7.22280.04, 72228004, 7.22280.04.0, 722280040
Coolant shut off valve, Meyle 0148000052
The oil pump was available when I checked a year or so ago. It was about $800. I’m running the Cup version of this pump. What was NLA was the actual external cooler itself along with a few other bits and pieces. I would simply call a dealer and give him the part numbers for latest availability status. Porsche does not repair gearboxes so if someone needs a repair, Porsche will only sell the gearbox complete with the cooler as a remanufactured unit.
I saw 2 pumps with vastly different prices, looks like one is 996, the other 997. No idea on the difference though, the 997 pump is listed on the G96/88 and G97/88, but the 996 pump, only on the 996 box.
99730702390....... $1,791.16
99630702390....... $ 639.12
There's also a few different oil cooler part numbers for the full assembly and parts, I'll update once I get clarification, but it seems the 996 oil cooler is used on both.
9963070158A...... Oil cooler complete
9963070208A...... Port plate (fits to pump)
99630720988...... Oil cooler
I've got a horrible feeling you might be right though, seeing as the box was sold without the cooler... If that's the case, I suppose i'd have to look at hooking up a laminova heart exchanger to the pump outlet.
What's the part number of the cup version?
I've got a horrible feeling you might be right though, seeing as the box was sold without the cooler... If that's the case, I suppose i'd have to look at hooking up a modine cooler to the pump outlet.
Did the parts supersede to 997/991 part numbers? I have found that they are not always the best about documenting superseded parts. A perfect example is the RWD front tension bolts. They have 15 different part numbers depending on model and year that all are superseded to two different options. And depending on which model you track to may not show that part number as a suitable substitute/replacement. Frustrating.
Originally Posted by s65e90
add a small pump
But a pump just recirculates and cools the fluid without the added lubrication that the factory setup adds with a pressurized oil stream. Just pulling from the sump and pushing through a cooler then dumping back in is great for cooling, but not what I would do if I were to add a cooler setup.
IMO adding the capacity and cooling to the fluid should be more than sufficient for most. Is there any data to show adding the spray bar is the way to go. I think someone did it before, IMO seems like a lot of work. Adding the cooler and lines with pump to drop temp is pretty simple.
pwdrhound
Apr 14, 2018 12:21 PM
pwdrhound
Oct 1, 2012 03:10 AM
