350mm rotor pad size
Old Nov 21, 2018 | 06:43 AM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
I run pfc pads up front on my car. With 997 sized 350 rotors I use 991 sized pads up front. I noticed some floating rotors call for using the 7819 size pad because of a smaller friction surface. I'm thinking about going to girodiscs up front for this year. How do I know what pads are correct, 991 or 7819 (the friction surface is 65mm vs 62mm on these)
Old Nov 21, 2018 | 11:49 PM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
Why not just using the pads for your 6GT2/3 caliper?
Old Nov 22, 2018 | 06:47 AM
jdexter's Avatar
Different size pads fit. They match the rotor. In this case the answer is the same pad... girodiscs use the 0991, however if you use 350mm rotors from pfc, they use the 7819 pad...
Old Nov 22, 2018 | 01:16 PM
VAGscum's Avatar
IIRC you either have pad hitting the rotor hats or not maximum pad contact.
Old Nov 22, 2018 | 04:01 PM
pwdrhound's Avatar
As per my email, Girodisc use PFC991 pad (65mm annulus)
Old Nov 22, 2018 | 04:06 PM
jdexter's Avatar
Yup. Thanks John. I made this post before I asked you.
Old Nov 22, 2018 | 04:30 PM
pwdrhound's Avatar
Gotcha. Happy Thanksgiving!
timccloud
Jun 1, 2017 03:12 PM
mtlsp
Feb 10, 2014 12:02 PM
smithk3933
Jun 19, 2013 10:18 PM
Al Norton
Oct 18, 2008 02:30 PM
