Spacers - My take
Old Dec 4, 2018 | 01:33 PM
darr3239's Avatar
darr3239 is infamous around these parts
Spacers - My take
Bought a 996TT a couple of months ago. There was a lot of shake in the steering wheel and the previous owner mentioned balancing and said the tires may have a little flat spotting to them.
I had the front tires balanced at Discount Tire which eliminated about half the issue. I was fairly certain that the wheels were OK and had my son, a lead Nissan mechanic for a number of years, balance them again by going so far as rotating the tire on the wheel for the best balance. His work seemed to produce no real improvement.
My son mentioned that spacers can produce a number of issues and recommended I remove them. I then removed the two front aluminum spacers and magically I've got no shake, other than what I would consider normal feedback from the road surface. Problem solved.
I'm wondering if others have had this experience and ultimately traced it back to the spacers?
Old Dec 4, 2018 | 01:59 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Most name brand hub and wheel centric spacers are fine. If they aren't hub/wheel centric you can have vibration problems.
Old Dec 4, 2018 | 02:21 PM
darr3239's Avatar
I don't know the brand name of the spacers, but the previous owner was a Porsche Club of America instructor, and an engineer by trade. He modified the car with PSS9 coilovers and H&R springs, along with a GT2 clutch conversion. So, I doubt he bought the spacers on the cheap.
Maybe he got a bad set?
Old Dec 4, 2018 | 02:38 PM
HotRodGuy's Avatar
it's possible, but i've never witnessed it in person. Have a picture of them by any chance?
Old Dec 4, 2018 | 03:23 PM
darr3239's Avatar
Old Dec 4, 2018 | 08:08 PM
'02996ttx50's Avatar
i ran 7x15 spacers for a few years on twists, lowered an inch or more. never an issue. i've never heard of spacers causing this.
Old Dec 5, 2018 | 06:53 AM
HotRodGuy's Avatar
Originally Posted by darr3239
They don't appear to be hubcentric. They should have a lip for the wheel to mount on.
http://www.ecstuning.com/marketing/P...r_ECS_WSKs.jpg
Old Dec 5, 2018 | 08:57 AM
darr3239's Avatar
The lip makes sense, but wouldn't all the wheel bolts center everything? I guess if the spacer holes were oversized a little it wouldn't.
Old Dec 5, 2018 | 09:05 AM
HotRodGuy's Avatar
They'd leave room for margin, and these cars i've learned are very sensitive to that. Stock you'd be resting on the hub, not the lugs, same would go with proper spacers
Old Dec 5, 2018 | 05:49 PM
darr3239's Avatar
For track use, with stock wheels, is there any advantage to using spacers?
Old Dec 5, 2018 | 07:04 PM
umm, wider stance?
Old Dec 6, 2018 | 08:10 PM
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
I had similar looking GMP spacers on my front wheels and had the exact same problem. Not matter what I did I couldn't get rid of the shake without removing the spacers. I now only run them in the rear. Totally smooth steering wheel.
Old Dec 10, 2018 | 08:37 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
Spacers are often not as big an issue as they are made out to be. The 930 came from the factory with (relatively large) spacers. Using spacers can even improve handling in some cases due the increased track width. In general, spacers are used more for looks than true performance gains in order to "fill out" the wheel wells.
As HRG mentioned, your spacers do not appear to be hub-centrc. And the lugs do not adequately locate the wheel to eliminate vibration.
Old Dec 10, 2018 | 09:36 AM
darr3239's Avatar
Thanks for all the replies. Like everything, quality matters.
ECS Tuning - VW
Aug 29, 2014 11:28 AM
Eurorus
Nov 30, 2007 06:31 PM
ceboyd
Aug 1, 2005 07:57 PM
